squeak in frontend.
Discussion in 'Suspension' started by metrick1215, Aug 3, 2022.
  1. Aug 3, 2022 at 7:03 PM
    metrick1215
    metrick1215 [OP] Pirate Medic
    Habersham GA..
    Black 2008 4x4 4door
    So im trying to trace a squeak in the front end of the truck.
    2008 Tacoma 4door 4x4 250,000 miles
    So heres where im at:
    new Balljoints last October on both sides. they were needed. Moog replacement, put in by a reputable shop. Passenger side does have a leak in the boot (i am going to try and put some grease in them this weekend and see if thats it)
    Power steering fluid topped off but wasnt low.
    When i bounce the front end, no squeak so not shocks or springs. (5100's on stock springs)
    Put new CV axles last year also
    Mostly squeaks when i am turning and one side is higher than the other in the turn. Does not make a noise when going down the road that i can tell. Doesnt make any noise when sitting still and turning the wheel.
    also plan on jacking the truck up and checking wheel bearings this weekend.
    Anything else i should check?
  2. Aug 4, 2022 at 6:38 AM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    Most common squeaking problem I hear about is the sway bar links. If they're still on there, disconnect them and see if it goes away.
    metrick1215[OP] and JFriday1 like this.
  3. Aug 8, 2022 at 1:15 PM
    TVH475
    TVH475 Well-Known Member
    Montrose CO
    I got my squeak narrowed down to lower control arm bushings, but I may disconnect a sway bar link just to verify, its free!
    metrick1215[OP] and Crikeymike like this.
  4. Aug 9, 2022 at 2:10 PM
    metrick1215
    Habersham GA..
    so due to weather this weekend and work, i wasnt able to get it looked at. So going to try again this coming weekend.
