Squeak in reverse..
Discussion in '1st Gen. Tacomas (1995-2004)' started by Polar6667, Aug 7, 2014.
  1. Aug 7, 2014 at 8:50 AM
    Polar6667
    Polar6667 [OP] Member
    Washington
    2000 Tacoma TRD
    After I lubed my drivetrain I have been getting some squeaking when I pull out of parking spaces. Just recently the squeak, which sounds like someone jumping on an old mattress, has started when I drive as well as back up but not as loud... The noise seems to be coming from the rear drive shaft/propeller shaft. Aft of the center bearing...
    Any ideas? U-joint? Center/hanger bearing?
  2. Aug 7, 2014 at 9:46 AM
    hondamxracer
    hondamxracer Well-Known Member
    I just noticed my truck started doing this too!
  3. Aug 7, 2014 at 9:49 AM
    TacoMitch93
    TacoMitch93 Tasty Taco
    Mitch
    Nova Scotia, Canada eh
    09 Tacoma SR5
    Leaf springs? Mine squeaks allllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllllll the time.
  4. Aug 7, 2014 at 12:18 PM
    Polar6667
    Washington
    2000 Tacoma TRD
    It's not leaf springs, it only happens when in gear
  5. Aug 7, 2014 at 12:29 PM
    TacoMitch93
    Mitch
    09 Tacoma SR5
    have you greased your u joints in your driveshaft?
  6. Aug 7, 2014 at 12:31 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    In gear and not moving? Or squeaks while actually reversing?
  7. Aug 7, 2014 at 12:36 PM
    Polar6667
    Washington
    2000 Tacoma TRD
    I have greased them. The squeaking started after but it had been probably too long since the were greased last. Old grease did come out, so not dry.. Happens when I back out of a parking space.. In gear, moving
  8. Aug 7, 2014 at 3:50 PM
    68dave
    68dave Well-Known Member
    Dave
    Baltimore/WV mountains
    $500.00 project 04 TRD 4x4 Lifted 4runner Stock Tacoma TRD Lifted 94 FZJ80 Stock 95 FZJ80
    Toytec Boss kit & OME leafs, 231mm tundra brakes SCS wheels...
    Brake pad wear indicator? I've had customer's vehicles only squeal when backing up, just a thought.
  9. Aug 7, 2014 at 5:56 PM
    afd23a
    afd23a Well-Known Member
    The Dynamo of Dixie
    05 Access Cab 5 Lugger
    Factory Fog Lights, Removed Secondary Air Filter, Metra Ipod Adapter, Int Wiper Stalk, Wet Okole's, URD Short Shifter, Scanguage II w/Blendmount, Fat Bob's 2.75" spacer lift, ARE topper, SP Performance Pads & Slotted Rotors, 4.10 gears
    Probably u-joints. That's what mine did when they were shot.
  10. Aug 7, 2014 at 7:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    U joint(s)
  11. Aug 8, 2014 at 7:30 PM
    Polar6667
    Washington
    2000 Tacoma TRD
    Defiantly not the brakes. I do know that sound, and my brakes have all been done recently.
    How would I know which u-joint? Haven't noticed any play/clunking when moving the drive shaft by hand...
  12. Aug 9, 2014 at 10:05 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    They dont always "clunk" at first, usually the first sign is a sqeaking, its the needle bearings chewing on one another the clunk is when they're coming apart
  13. Aug 9, 2014 at 10:16 AM
    mnerren
    mnerren 2006 Tacoma TRD Sport XSP
    Jacksonville, FL
    2006 Tacoma TRD Sport Double Cab
    Mine did that and it was the U-joints.
  14. Aug 11, 2014 at 5:10 AM
    Polar6667
    Washington
    2000 Tacoma TRD
    So when ordering parts, are the Toyota u-joints superior over Moog, ACDelco or Dana?
  15. Aug 11, 2014 at 9:00 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I couldn't really tell you but FWIW my U joints are original :)eek: true story)
    @ 206,783 miles.....I'm happy with the OEM's ...
  16. Aug 11, 2014 at 3:29 PM
    yummjake
    yummjake Well-Known Member
    Jacob
    Richmond, VA
    00' EXT Tacoma 4wd
    5100's, Toytec coils, all-pro standard 3" lift leaf springs.
    I had a squeak that started out only happening in reverse, progressively it began to squeak while moving forward too. Just changed out the rear most u-joint today, the one at the diff, now my truck is quiet and I'm a happy camper. Three out of the four caps on the old u-joint looked alright, needle bearings intact, the last one, had only dust in it, which I'm guessing is what was left of the needle bearings in that one. :eek:
  17. Aug 12, 2014 at 5:59 AM
    hondamxracer
    What u-joints did you decide to go with? Thinking about replacing mine.
    Camelbak Toyota has them listed at $52, but aftermarket's are less than $15.
  18. Aug 12, 2014 at 6:36 AM
    Polar6667
    Washington
    2000 Tacoma TRD
    I haven't decided yet, one dealer said $70, rock auto has them from $5-$30. I won't go w the cheapest but it's not clear if Toyota is really 2.3 times better..
