Squeak in the back!!!help me
Discussion in 'Suspension' started by 4ari trd, Jul 18, 2010.
  1. Jul 18, 2010 at 3:38 PM
    4ari trd
    4ari trd [OP] Well-Known Member
    portland, oregon
    08 trd sport double cab long bed
    cat back magnaflow exhaust- stage 2 k&n intake- URD MAF Sensor Calibrator, Westin bull bar, black housing headlights, yellow fogs, 10000k hid, fog light mod, 3in tuff country lift
    my back end is squeaking really bad and its so gay..i dont know what is it or how to fix it i tried spraying lube all over the leaf springs and it just doesnt help...Any ideas?
  2. Jul 18, 2010 at 3:43 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    probably need to pressure wash your rear springs and may have to pry up on them and spray some good dry moly lube back there on the silencer pads and all between the leafs. dont use stuff like wd40....it attracts dirt/dust.
  3. Jul 18, 2010 at 3:54 PM
    AKTacoma
    AKTacoma Dedicated Crew Chief
    Houma, Louisiana
    08 Tacoma DCLB
    X2 I've used dry lubes or even lube with teflon in it worked for me
  4. Jul 18, 2010 at 3:59 PM
    4ari trd
    portland, oregon
    So it's not the shocks it's the leaf springs. I cleaned them good I just need to buy some good lube. Where can I get some good lube.
  5. Jul 18, 2010 at 4:00 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    autozone/pep boys/advanced...tractor supply...they all carry some different stuff.
  6. Jul 18, 2010 at 4:06 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    My leafs were squeeking and they were cracjed right where the ubolt is
  7. Jul 18, 2010 at 4:36 PM
    DevL
    DevL Well-Known Member
    Mine squeak at all 4 wrap points everytime I wheel or every 2 weeks which ever comes first. The solution is to have CLEAN leaf springs (presure wash the crap out of them). When dry, I spray Liquid Wrench silicon lube on and in the 4 wrap points on the leaf springs. By the time I get to where I am going or come back if I just let it sit the springs dont squeak. Its not the leaves, the shocks, or the U bolts... its the wraps that squeak on my truck (2010 DC 4x4) and all 4 squeaked after the first time I got em muddy/dirty. Lubing any other area does nothing for me. Just the wraps.
  8. Jul 18, 2010 at 4:49 PM
    4ari trd
    portland, oregon
    That's what I kinda thought I'll try that
  9. Jul 18, 2010 at 4:51 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Mine did the same thing so i got some white grease and pryed the springs apart so far so good. :thumbsup:
  10. Jul 27, 2010 at 10:36 PM
    DevL
    Im trying white lithium spray grease to see if it lasts longer than liquid wrench silicon lube. Its only $3 a can at Oreillys
