Squeak in the front suspension.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by hondarider215, Mar 21, 2013.
  1. Mar 29, 2013 at 7:32 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    I had a very similar sound on my 1st gen. The bottom eyehole of the strut tht mounts to the lca was rubbing on the lca strut mounts, so the shock was twisted in the mount causing metal on metal screech noise like that.
  2. Mar 30, 2013 at 9:34 AM
    hondarider215
    hondarider215 [OP] Well-Known Member
    Wes
    Socal
    KR Tacoma
    KR Fabrication front and rear bumper ICON 2.5 c/o's All pro leafs Maxtrac Fox rear resi shocks Lr uca 17" methods
    How did you fix it?
  3. Mar 31, 2013 at 6:34 AM
    sir1123
    Charleston
    It was on my first lift (skyjacker). I then got 5100s and ebaichs which is how I went about it. I never had a fix for it but to spray it with lube.
  4. Apr 16, 2013 at 11:26 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    I have a very similar problem here with my ICON LT and TC UCA. I'm sure it's not the UCA bushings and done some tests to clear the ball joint possibilty. Doesn't seem to be related to the swaybar bushing either.
    I can feel the vibes when i put my hands on the coil.
    Let us know about ICON comments. It sounds just like a very tight/dry seal on the coilover shaft.
  5. Apr 16, 2013 at 9:00 PM
    tcma07
    tcma07 Chris
    C.C. Texas
    2007 Sport 4x4 v6 A/C Blk
    4" lift, Satoshi, BHLM...
    had that same problem with my LR UCAs it was the ball joints forced the boot back and stuffed with grease went away instantly
  6. Apr 17, 2013 at 9:53 AM
    hondarider215
    Wes
    Socal
    KR Tacoma
    I told the guy at icon to that it sounds like something needs to be lubed like the bushing on the lower shock mount but he said there made so they don't need any.
    There at ICON right now should have them back this week or next week. Guess they only rebuild shocks on Tuesdays.
  7. Apr 17, 2013 at 9:56 AM
    hondarider215
    Wes
    Socal
    KR Tacoma
    Yeah I've read through most of the threads about squeaky shocks but all come to an end with no conclusion about how to fix it. I've tried to spray the crap out of the shock with dry lube but anywhere I sprayed it the squeak was still the same. I've read one guy had to go as far as replacing the lower bushing, where the lca mounts, on his ICON shocks to make the squeak go away
  8. Apr 17, 2013 at 9:57 AM
    hondarider215
    Wes
    Socal
    KR Tacoma
    I had the squeak before the LR uca's. I bought them to see if it was just my stock uca making the squeak.
    As of right now I have my stock shocks back on with no squeak so it was the ICON shocks.
  9. Apr 18, 2013 at 5:28 PM
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    I had a set of SwayaWay on my 1 gen and shortly after installing them I started to get that same squeal. Back when those were made the shock shaft was on top. It ending up being the seal at the shaft. I was able to take some axle grease and put it around the shaft were it went into the shock body. Never had the squeak again.
  10. Apr 19, 2013 at 1:48 PM
    hondarider215
    Wes
    Socal
    KR Tacoma
    The guy at icon had me do that before I sent them in but it didn't do anything really. That video I posted is with some lube on the shaft
  11. May 1, 2013 at 10:06 PM
    hondarider215
    Wes
    Socal
    KR Tacoma
    Update: received my shocks back yesterday and installed them. The squeak is gone! I talked to the guy that rebuilt my shocks and he said the went and replaced the seals so I guess that was the issue.
  12. May 1, 2013 at 10:27 PM
    hondarider215
    Wes
    Socal
    KR Tacoma
    Maybe. I'm not to sure. The guy told me that sometimes just tightening the shocks down more takes the squeak away. He said every case is different. Have you tried putting some grease on the shaft? They told me to do that but it did nothing. They told me it might quiet them down.
  13. May 24, 2013 at 6:34 PM
    tacoma guy
    Joe
    Phoenix Az.
    Is this a common issue with the icons ? How many others running the icons
    have had this issue? I am thinking of possibly getting the icons. But don't wont to deal with this issue. Thank you in advance .
  14. May 24, 2013 at 6:49 PM
    tacoma guy
    Joe
    Phoenix Az.
    Yeah I am leaning toward the 5100 myself. Just thought it would be cool to have the option of being able to fine tune height adjustments. Thanks for your personal experience. :D
