Squeak mystery in 2020 tacoma.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zoo truck, Mar 5, 2021.
  1. Mar 5, 2021 at 8:37 AM
    zoo truck
    zoo truck [OP] Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Finally solved the mystery squeak in my tacoma that seemed to come and go depending on the temperature.
    I wouldn't of thought this, but discovered the cause, or at least where its originating from. I decided to readjust my articulating steering wheel. When pulling it upward, and in and out lo, and behold...it made the same squeak. Well after a few times moving the wheel around the squeak vanished. Drove the truck this morning in 20 degree temps...no more squeak. It would of done it for sure.
    Doobfucious likes this.
  2. Mar 5, 2021 at 8:40 AM
    RedWings44
    RedWings44 Well-Known Member
    Michigan
    2017 Black TRD Off Road 4x4, 2019 MGM 4Runner SR5
    Glad you found it! Those can be hard to chase. I'm currently trying to figure out one from my driver's door. When I go over certain bumps it almost sounds like the window is shifting within the trim, but if I listen, it'll still do it with the window down. It doesn't seem to be affected by wind.
  3. Mar 5, 2021 at 10:18 AM
    zoo truck
    None
    Only noises i ever got that were in my tundra's door hinge when they needed some lubrication, or, maybe you'll locate it by accident as i did.
    RedWings44[QUOTED] likes this.
  4. Mar 5, 2021 at 12:02 PM
    DPJ
    DPJ Well-Known Member
    NE Florida
    White DCSB 4 cyl 2WD automatic
    I found the window track loose in one of my rear windows. Removed the door panel and tightened one nut. The nut was off the other. I found it in the bottom of the door and put it back on. Sometimes I wonder what else might have been not tightened enough.
