Squeak noise front left 07 Tacoma 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kylecaz4, Jun 2, 2019.
  1. Jun 2, 2019 at 10:04 PM
    Kylecaz4
    Kylecaz4 [OP] Active Member
    2007 Toyota Tacoma sr5
    Hey guys I joined to try and figure out if someone knows what’s up with the truck. Doesn’t seem to affect the way the truck drives but the rig makes a constant squeaky noise while driving down the road no matter what I’m doing??? Any help would be great
  2. Jun 2, 2019 at 10:07 PM
    Beretta4x4
    Beretta4x4 What makes the green grass grow? TTC#0114
    Josh
    Temple, TX
    6-speed death mobile
    Welcome! Videos and pictures will help as will a more detailed explanation of what's going on.
  3. Jun 3, 2019 at 4:41 AM
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
    If it’s a constant very high pitched squeal, it’s probably the wear indicators on the brake pads. Jack the offending wheel up and spin it.
  4. Jun 3, 2019 at 8:00 AM
    Kylecaz4
    Would it be squeaking all the time? No matter what I am doing just driving down the road it is squeaky.
  5. Jun 3, 2019 at 8:01 AM
    Beretta4x4
    Josh
    Temple, TX
    Does it only do it driving or can you duplicate it with the vehicle stationary?
  6. Jun 3, 2019 at 8:22 AM
    Kylecaz4
    Only when driving...if I press hard on the wheel when it is sitting still I can kinda hear it but not sure if it’s the same thing definitely hear it when driving
  7. Jun 3, 2019 at 11:04 AM
    Foghorn
    North Cackalacky
    2014 DCSB Off Road
    This video explains the wear indicator pretty well. This is the first thing I would check. Of course, this would only be on the front wheels of your Tacoma.
    https://youtu.be/8BL-6JhRRJk
  8. Jun 3, 2019 at 11:44 AM
    Kylecaz4
    It’s not nearly that loud..... it’s just like a true off and on squeak but happens the whole time while driving. It’s like squeak squeak squeak squeak not squuuuuueeeeeeaaaaaakkkkkkkk idk if that helped?
  9. Jun 3, 2019 at 11:47 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    Sounds suspension related to me. Is it coming from the front or the rear of the truck? If it's the rear it's most likely squeaky leaf springs which is really common. Blasting them with a high powered hose usually helps for a time. There are other threads on here regarding long term solutions to squeaky leaf springs, if you type it in the search you'll see a bunch of them.
    If it's coming from the front you'll have to try and narrow it down to exactly where. When my front end was squeaking I was able to narrow it down to my lower coilovers by rocking the truck back and forth while standing next to the door.
  10. Jun 3, 2019 at 11:48 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    Ball joint
  11. Jun 3, 2019 at 1:04 PM
    Dimestore55
    Dimestore55 Well-Known Member
    William
    Richmond, VA
    2007 TRD OR Prerunner DCSB
    The wheel bearings are a definite contender here. I have an '07 and I replaced the left one @ 91k miles and just yesterday the right one @ 131k.
  12. Jun 3, 2019 at 1:25 PM
    Kylecaz4
    We’re they squeaking high pitch kinda quite but very noticeable? How much are they to replace?
  13. Jun 3, 2019 at 1:37 PM
    eon_blue
    Azusa, CA
    Wheel bearings typically make a grinding noise when they are going bad, particularly when turning, and are easy to diagnose by lifting the front wheels off the ground and checking for play by grabbing the tire at the 12 and 6 o'clock positions. And not cheap to replace at all, I wouldn't put my money on it being the wheel bearings based on what you're describing.
    Squeaking while driving down the road is most likely coming from your suspension...dirty or dry bushings, bearings, ball joints...hard to say without more info.
    Maybe try and recreate the squeak by rocking the truck back and forth and take a video of the area it's coming from so we can see/hear.
  14. Jun 3, 2019 at 2:23 PM
    TACOMA2NDGEN
    TACOMA2NDGEN Well-Known Member
    ROLAND
    new jersey
    2010 dcsb silver sport trd
    baja squadron pros
    Could it be your u joints? Does the squeak get faster as you drive and vice verse when you slow down, does it go away at highway speeds?
  15. Jun 3, 2019 at 2:35 PM
    Kylecaz4
    I’d say yes it does squeak faster not Necessarily louder the faster I go but it doesn’t go away at highway speed no.
  16. Jun 3, 2019 at 2:36 PM
    eon_blue
    Azusa, CA
    If it's drivetrain related like u-joints then it would be more in sync with the speed/spinning of the driveshaft. If it's suspension related it would be in sync with the ups and downs of the road terrain.
  17. Jun 3, 2019 at 6:32 PM
    DKRdad
    DKRdad New Member
    2008 Tacoma TRD
    My case is probably a one-off, but I thought I'd share. I had a loud squeak coming from the front left side on my 2008. I've only had the Tacoma a few weeks, but it was driving me nuts. I couldn't duplicate it when it was standing still, but I still thought through all the options discussed - it sounded like an old suspension. Then, I realized I only heard when I was driving with the window all the way open. Sure enough, I raised the window just a nudge and the squeak stopped. Couldn't believe it had been so loud that I thought it was suspension related! Anyway, thought I'd share, just in case it is that simple.
  18. Jun 4, 2019 at 3:59 PM
    CStafford
    CStafford Well-Known Member
    Cameron
    2006 Silver Tacoma TRD Access
    I'm not sure if I have the same squeak going on, here is a video, you can faintly hear it while I'm driving about 30-35 mph
    https://www.youtube.com/watch?v=O7VEJBSNVJc
    *VIDEO IS NOISY (wind), OPEN WITH CAUTION*
  19. Jun 4, 2019 at 5:58 PM
    Kylecaz4
    YES! Literally the same sound! What the heck is it!!!
  20. Jun 4, 2019 at 6:04 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Sounds like you may have a baby dolphin stuck in your undercarriage.
    Lucifer29 and VanDoom like this.
