Squeak noise front left 07 Tacoma 4wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kylecaz4, Jun 2, 2019.
  1. Jun 4, 2019 at 6:05 PM
    Kylecaz4
    Kylecaz4 [OP] Active Member
    2007 Toyota Tacoma sr5
    Lmao, take it u don’t know either?
  2. Jun 4, 2019 at 6:17 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Well, I mean it could also be a large squirrel or less likely a raccoon.
    Sounds like radiator mount bushing is worn out and moving around a bit.
  3. Jun 4, 2019 at 6:19 PM
    CStafford
    CStafford Well-Known Member
    Cameron
    2006 Silver Tacoma TRD Access
    Wish i knew... Lol I can't replicate it by pushing on the rear end so I don't think it's the leaf springs and the spare tire is snug.
    Mine just started a few months ago and I hate driving with my windows down because of it
  4. Jun 4, 2019 at 6:47 PM
    Kylecaz4
    Please let me know if u figure it out! Mine is literally the same thing and it don’t affect anything but my music needs to be on bc it drives me stir crazy
  5. Jun 4, 2019 at 7:56 PM
    slamrock
    slamrock Member
    2010 Super White Tacoma TRD sport
    I have a squeak that sounds the same except mine is only when going over bumps.
    I have tried to replicate it by bouncing the front end and rear end up and down and cant get it to happen
  6. Jun 4, 2019 at 8:00 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    My dad had a huge squirrel living next to his battery in his F250. Did you pop the hood to look for anything OP?
  7. Jun 4, 2019 at 8:08 PM
    CStafford
    Cameron
    Hard to tell in the video but it only really squeaks going over little bumps.
  8. Jun 4, 2019 at 8:15 PM
    slamrock
    slamrock Member
    ok so maybe mine just hasn't gotten that bad. It used to only do it over pothole type bumps on the road and its slowly getting worse. I've even noticed it going across a crosswalk paint if it bumps up enough. Also If I hit a rumble strip line on the shoulder it turns into rapid fire squeak-squeak-squeak-squeak to the point it's almost a steady squeak
  9. Jun 4, 2019 at 9:28 PM
    Kylecaz4
    Yeah man I can’t figure it out but it’s super annoying.
  10. Jun 5, 2019 at 8:25 PM
    becauseracebike
    becauseracebike Member
    2008 Blue Ribbon Tacoma TRD SR5 4x4 V6
    2.5" lift, Duratrac's, Viper Alarm, Panorama S dash cam, 12V constant power mod, tonneau cover
    I had this. Greasing the prop shaft zerks fixed it. I have a creaking/rubbing sounds coming from the front-end going over bumps and driveways still though. Old/dry bushings maybe?
  11. Jun 5, 2019 at 8:41 PM
    Kylecaz4
    Was ur truck making that same sound isn’t he video above??
  12. Jun 5, 2019 at 8:44 PM
    becauseracebike
    Yup...chirpity chirp chirp. Got so loud it'd turn heads.
  13. Jun 5, 2019 at 9:24 PM
    Kylecaz4
    Where are the prop shaft zerks? Are they easy to grease on own?
  14. Jun 5, 2019 at 9:29 PM
    becauseracebike
    You should be able to just slide under the middle of the truck and see the shaft plainly. Zerks are on either end. I missed one way up towards the front and greased that recently. Took the chirping away. NLGI 2 grease is what's recommended I believe. There's a full how to thread on here that I followed. There's one zerk to not overfill so please research thoroughly first.
  15. Jun 6, 2019 at 6:13 AM
    #35
    Foghorn
    Foghorn Senior rooster, instructing in the art of roostery
    North Cackalacky
    2014 DCSB Off Road
  16. Jun 6, 2019 at 6:19 AM
    #36
    Lucifer29
    Lucifer29 Well-Known Member
    Red
    I got that same crap.......grr mine with window up sounds like its coming from right coener of dash a lil mouse squeaking or some shit
  17. Jun 6, 2019 at 7:06 AM
    #37
    CStafford
    Cameron
    I crawled underneath my truck to grease my zerks the other day and i'm wondering if I have any?? I looked at the how to here on TW but it seems like they were just not there..
    I did have all my u-joints replaced recently on the extended warranty extension program, would they have replaced them with the non-greasable ones?
  18. Jun 6, 2019 at 11:11 AM
    #38
    Kylecaz4
    Normally no....if they replace them it would be with the greasable ones....
  19. Jun 6, 2019 at 11:11 AM
    #39
    Kylecaz4
    Have u taking it to the mechanic yet? If u figure it out please let me know!
  20. Jun 6, 2019 at 11:50 AM
    #40
    eon_blue
    Azusa, CA
    The zerk fittings are inside the u-joints and can be easy to miss especially if they're covered in dirt/road grime. Also sometimes you have to move the truck forward or back to spin the driveshaft so you can see the zerks, depending on what direction they're pointing when you park.
