Squeak noise suspension
Discussion in '3rd Gen. Tacomas (2016-2023)' started by blacktaco77, May 13, 2025.
  1. May 13, 2025 at 6:41 PM
    blacktaco77
    blacktaco77 [OP] Well-Known Member
    Noah
    21 TRD off road black 4x4
    Been trying to this passenger side squeak… I have eliminated the core support mount bushings as I just replaced them. Also ball joints don’t have any play in them and are greased regularly. Narrowed down to the lower shock heim supposedly they go out on kings quite frequently or lower control arm bushings. Maybe the upper control arm heims from accutune but the arms are fairly newer. Gonna be replacing the boots on those ball joints as they have ripped and wanna fix this noise while I’m down there doing that. Curious if anyone has any input before I buy some more parts that won’t fix the noise thanks.
    squeak vid https://youtube.com/shorts/wSj_oCtTGKY?si=N3uT-AWUnMDtqFPq
    HondaGM likes this.
  2. May 13, 2025 at 6:48 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    I would get somebody to bounce it while I got under there and listened…shouldn’t be hard at all to pin point that.
    helix66 and blacktaco77[OP] like this.
  3. May 14, 2025 at 12:37 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    Let me know what you find, I have a similar creaking sound when I'm backing out of a parking spot or into the garage. I can replicate by rocking the truck as well. I'll have to recruit my wife or kids to rock it while I crawl around and chase the sound.
    71tattooguy and blacktaco77[OP] like this.
  4. May 14, 2025 at 4:41 PM
    blacktaco77
    Noah
    Going to look into this weekend and I’ll update
    71tattooguy likes this.
  5. May 15, 2025 at 5:27 AM
    rndsommer40
    rndsommer40 Well-Known Member
    Ralph
    2022 TRD OffRd DCSB
    I had similar noise. Dealer replaced front shocks under warranty after numerous complaints and visits. 6 months later it started again but not as loud and on the pass side this time. I just dealt with it and it has since stopped on its own.
  6. May 15, 2025 at 5:48 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    I have the same noise :annoyed:I just turn my music up LOL. I’m also running kings. Does not seem
    To be that. Recently stopped on its own :rofl:Keep me posted on what you find and Good luck
    BabyBilly likes this.
  7. May 15, 2025 at 8:05 AM
    AZPhys13
    I have 5100's in the front so it seems to be a problem with another component
    71tattooguy[QUOTED] likes this.
  8. May 15, 2025 at 9:13 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    Are there any poly bushings on it?
    Yours definitely sounds more like a squeak, I was chasing a pretty loud creaking sound when I pull in/out of my driveway.
    Rocking the truck didn’t duplicate it.
    I grabbed a can of tri-flow (any lube would work) and started hitting any joints one at a time.
    I suspected the LCA or sway bar bushings and the dealer wanted 2700 because they replace the whole LCA (I don’t have a press).
    @AZPhys13 when I dropped my RCI front skid plate the sound was gone. Somehow it must have sprung and was causing the sound.
  9. May 15, 2025 at 9:17 AM
    AZPhys13
    I'll have to check the skid as well. I have the TRD knock off and wouldn't be surprised if it was creaking.
    helix66[QUOTED] likes this.
  10. May 16, 2025 at 1:01 PM
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    @blacktaco77 did you find it yet? I will say that when I go hunting for squeaks I almost always find them at the UCA, followed by swaybar bushings, and then skid plates. Clunking/shifting are where I start looking at lower shock mounts, end links, etc.
    @AZPhys13 - GO CATS! :cheers:
    71tattooguy and AZPhys13 like this.
  11. May 23, 2025 at 9:02 PM
    blacktaco77
    Noah
    Sorry for the late update. I am 95% sure the noise is the king shocks I unbolted and silicones the bearing and noise went away temporarily. Ordered some new bearings from 303 shock services, hopefully can get them on this weekend. For those with kings also they recommend using hardware that isn’t tapered for the lower shock mount, maybe this applies to other tacoma shocks not sure but the bolt doesn’t fully contact part of the heim and leads to premature wear.
  12. Jun 3, 2025 at 10:11 PM
    piotr1aj
    piotr1aj Well-Known Member
    Seattle, WA
    ‘17 OR QS/DCSB/MT
    Yea that sounds like a lower shock mount issue; I had something very similar a while back. The lower bearings in kings don’t last super long from what I’ve experienced, especially with the stock bolts being tapered as you noted.
    I ordered new bolts/bearings from 303 as well and that eliminated my issue. Inspected my bearings recently during a rebuild and noticed one was beginning to fail (just under 2yrs). Recommend inspecting/replacing the lower shock hardware for kings on a more frequent interval.
  13. Jun 4, 2025 at 2:53 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    My Son's truck made the noise very similar to the video. We rocked and bounced on the bumper but never found. Then the next day we were starting to grease the suspension, and he folded the tonneau cover up, stood in the bed and no noise. He folded the cover back up and the squeak returned. We opened the cover again and bounced and the squeak returned. After checking we found the bolt on the OEM cover was loose, so we tightened and never heard it again. Long story short check your tonneau cover if you have one.
    doublethebass likes this.
  14. Jun 4, 2025 at 4:47 AM
    Chiggy215
    Chiggy215 Member
    2023 Tacoma TRD OR
    Sounds like you may have solved this already, but for reference for others with a similar issue:
    I had a squeak on my tacoma very close to this, turned out to be some sand/dirt that had worked its way to the bottom of the driver side spring. I cleaned the area gently with pressured water and then used a little wd-40 on the bottom plate the spring sits on - no squeaking since then. Try getting a spray bottle and squirt some water in that area, then bounce on the truck and see if it goes away. If it does, then get in there and clean it out really well.
  15. Jun 4, 2025 at 5:18 PM
    cwk84
    cwk84 Well-Known Member
    2019 TRD OFF-ROAD
    Sounds like the spherical bearing. Take some WD40 and spray it liberally on the bearing where the shock mounts to the lower control arm. If it goes away, you know what to replace. If that isn't it, it could be the lower body mount located directly inside the wheel well. You would have to remove the liner to see it.
  16. Jun 5, 2025 at 6:07 AM
    rndsommer40
    Ralph
    2022 TRD OffRd DCSB
    Had my front shocks replaced under warranty because of squeaking. Started again 3 months later. Decided to just live with it. A few months later it stopped altogether. Been quiet now for almost 2 years. Maybe the fluid film application lubricated something. Who knows
    Canadian Caber likes this.
