Squeak noise
Discussion in '2nd Gen. Tacomas (2005-2015)' started by dwilliams81, Nov 15, 2022.
  1. Nov 15, 2022 at 6:39 AM
    dwilliams81
    dwilliams81 [OP] Well-Known Member
    2012 2.7L Tacoma 4x4
    2012 Tacoma 4x4 I had the brakes checked back in June 2022 due to noise and vibration pads were good the dealership turned rotors and adjusted and cleaned rear drums. Now when braking slow I can hear a squeak it doesn’t sound like a brake squeak but I’m not a mechanic. It’s a squeak that sounds like it’s rotating on the passenger side I can’t tell if it’s rear or front. What could it be? Wheel bearing, ball joint? Any thoughts or tests I could do?
  2. Nov 15, 2022 at 7:01 AM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Check the dust guards or some people call it the backing plates on the front rotors. See if one of them tin guards are rubbing up against the road or a little bit.
