Squeak on my 2015 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tacotuesday12, Jan 11, 2020.
  1. Jan 11, 2020 at 5:33 AM
    Tacotuesday12
    Tacotuesday12 [OP] Member
    I have a squeak coming from the bottom of the truck, I know it’s not the shocks because I just had them replaced as well as the lower and upper control arms. Has anyone had a similar situation and a way to fix it? Never had this issue on my 93 T100.
  2. Jan 11, 2020 at 5:40 AM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    Look for any new shiny spots near where you hear the sound coming from, something could be slightly rubbing. Best if you have another person give the truck a shake while you're under it..just wear glasses or you will get crap in your eyes. Good luck!
    2nd.. If you're running Dakars... get used to it. :anonymous:
  3. Jan 11, 2020 at 5:43 AM
    Tacotuesday12
    I’m on oem PugetSoundTaco..
    gravyboat likes this.
  4. Jan 11, 2020 at 7:19 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    Spray the leaf springs with fluid film
  5. Jan 11, 2020 at 8:16 AM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Did the "squeak" start after installation of the new shocks and UCAs ?
  6. Jan 11, 2020 at 8:20 AM
    diabetiktaco
    diabetiktaco Instalander
    Eric
    New Jersey
    2022 GX460
    That's never worked for me. Lucas motorcycle chain lube works wonders though.
  7. Jan 11, 2020 at 1:54 PM
    spitdog
    Chain lube and most lubricants should work fine as long as there reapplied periodically, nothing last. I like FF because it’s not petroleum based. It’s worked fine for me.
  8. Feb 12, 2020 at 4:10 PM
    Tacotuesday12
    Nope, it’s been there since the 5000 miles mark..
