Squeak on Start
Discussion in '1st Gen. Tacomas (1995-2004)' started by LifeIsGood169, Nov 1, 2011.
  1. Nov 1, 2011 at 11:49 AM
    LifeIsGood169
    LifeIsGood169 [OP] Well-Known Member
    Greg
    Philadelphia
    03 Tacoma XtraCab 2.7L 5spd
    Chime Mod Kenwood Headunit Greased all Zerks, locks, and bushings Reverse Flood Lights Extang Cover Weather stripped tailgate Burner Fog Lights Toggle Switches in Dash
    When I went to start the truck at lunch time there was a really high pitched squeal for about 5 seconds. It reminds me of those ricers you see going down the street with squealing cams (I think they are cams). Anyways, it went away in 5 seconds. I got out of the truck and checked around, couldn't hear anything.
    I have a 5 speed manual & I started the truck on a hill with the parking brake on & the shifter in H2 & Reverse (clutch in). The noise seemed to go away at the same time I moved the shifter from reverse to neutral. It did not come back when I put it back in reverse or first or let out the clutch 1/2 way for a split second with the brakes still engaged.
    Has this happened to anyone? First time I've heard it. Recommendations? Should I start leaving my truck out of gear in the winter? (i know the manual says not to use the parking brake below 32F, but I do anyway).
    Edit:
    my guess is something to do with oil pressure. Could the angle of the hill (nose down) have limited the oil going to the oil pump on start? Should a pump primer be installed? or an oilpan heater, or should I turn the ignition on and wait 10 seconds to twist to start?
  2. Nov 1, 2011 at 11:59 AM
    S.B.
    S.B. Well-Known Member
    Sean
    Colorado Springs, CO
    08 Taco 4x4 TRD OffRoad Rugged Trail
    Fox 2.5, Built right UCAs, CBI Front bumper, NWTI Rear bumper, 35s
    Check your fan belt and serpentine belt. And never use cheep belts, because they squeal like hell.
  3. Nov 1, 2011 at 12:02 PM
    Burgman
    Burgman I KEEEEEL YOU
    Stephen
    Ric VA
    08 PreRunner TRD sport Silver
    K&N intake, Boston Acoustic SL 60 6.5 components up front, Rockford Power T16 6.5 in rear, Pioneer P4100 HU, Soon to be Pioneer Prs 4200f
    squeaks like that are usually either belts or pulleys...
  4. Nov 1, 2011 at 12:14 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    +2 with above. Check the belt and pulleys-especially on the water pump and alternator. Usually it's a sign they are failing.
  5. Nov 1, 2011 at 5:14 PM
    newertoy
    newertoy Well-Known Member
    Kevin
    East Tn
    2003 4x4 extra cab
    2" lift AAL and Bilstiens-front-rear,front diff drop. main drive drop
    BELT--check and replace--saw somewhere to put "bar soap" on the squeaky belt.
    have not tried it--sounds logical. The cheaper belts squeak sometimes.
    They also stretch sometimes--especially when new.
    BTW--NICE TRUCK!!!!!!!!!!!
  6. Nov 1, 2011 at 7:03 PM
    UndefinedTaco
    UndefinedTaco I'll eat all your food.
    Justin
    Tracy, CA
    Toyota
    It's an 89 Toyota Pickup. I got some stuff done to it.. FJ axles going under it soon.
    Check your belts, check tension...could be the belts but your pulleys could be grooving from not tensioned within spec.
