Squeak/popping while turning into parking spot
Discussion in 'Technical Chat' started by Chickenmunga, Oct 17, 2011.
  1. Oct 17, 2011 at 3:29 PM
    Chickenmunga
    Chickenmunga [OP] Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    Hey all, hopefully you can save me a few dimes on solving this issue:
    when making a slow turn (usually into a parking spot), my front end will make several popping sounds. This has been happening for about a week. I thought I had maybe bent the brush plate and it was catching the wheel, but I wasn't at full wheel lock and I couldn't make it happen when I tried to creep slower.
    It happens less in reverse, and does not occur above 15mph or so, only when trying to park at home, the store, etc.
    Today it's gotten a bit worse, I get the popping OR a squealing noise - it sounds the same as if you were to try chirping the tires.
    the only other thing I can say is that I will sometimes get a single 'pop' if I put the passenger side under some sudden, decent flex - I can't jump up and down on the passenger side to do it, it has to be more substantial... though it doesn't happen all the time either, so I'm kind of dismissing that.
    From what little I can see, the CVs aren't leaking or torn looking.
    It doesn't happen while going straight, so there's nothing I assume with the brakes
    I have hit some potholes like an average person, but my alignment is OK from what I can see.
    I can admit that it's probably the abuse of offroading, and that's understandable, but what is going on?
    about the only thing the search found was a guy with a pitman arm that needed greasing, but I don't know what/where that is, and his probs were loosely related to my issue
    Help please! :eek:
  2. Oct 17, 2011 at 3:39 PM
    BakoTruck
    BakoTruck Well-Known Member
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    R U driving around with 4WD engaged?
  3. Oct 17, 2011 at 3:49 PM
    Chickenmunga
    Keizer, Oregon
    only on the trails, which have been muddy.
  4. Oct 17, 2011 at 3:54 PM
    BakoTruck
    Matthew
    Bakersfield, CA
    05 PreRunner TRD
    Well, I'm sorry I don't know what is causing it. The only thing I can say is for you to check underneath in the front to see if anything looks bad. Check the front axle areas, take the wheel off and check the steering, everything in that area.
    Hopefully someone else will help you better than me.
  5. Oct 17, 2011 at 8:31 PM
    KalamaKid
    KalamaKid Well-Known Member
    Oregon
    same shit as everyone else
    Sounds like it could be a worn out CV joint. How many miles are you at now? Have you reached down and played with them at all to see if there is any added play?
    Item 8 can get worn out much faster then usual with the larger tire diameter and force applied to it while in 4WD. If you have your wheels turned it puts even more stress on those bearings. The more stress that is added will wear that joint down and give you a little more play when moving forward or backwards. This could sound like a clicking noise.
    Also my sway bar occasionally hits my strut every now and then when I am moving forward and backwards at full lock.
    Check the torque on your LR UCA bolt.
    Check the torque on your top plates. Maybe something is loose from the last time you changed out your springs.
    Check the torque on your Lower control arms also. Maybe your last alignment shop screwed up.
    I'd do all that first before going to the dealership
  6. Oct 17, 2011 at 8:32 PM
    KalamaKid
    Oregon
    This too!
  7. Oct 17, 2011 at 9:36 PM
    Chickenmunga
    Keizer, Oregon
    I'm unfortunately still learning about trucks so I'm not sure what normal play would feel like. I had a dude check out my tie rod and he said that was good (in case I got the wrong word, it's the rod that isn't the CV that goes to each tire in the front... lol)
    I'm just over 43k
    I'm somewhat thinking it could be this...
    Sway bars? We don't need no stinking sway bars!
    I left that in Salem :mad:
  8. Oct 17, 2011 at 9:41 PM
    KalamaKid
    Oregon
    Did you try this yet?
  9. Oct 17, 2011 at 9:47 PM
    Chickenmunga
    Keizer, Oregon
    To avoid cross posting my whole response, nope, and not sure how I can do that with the damned little tools I have in this apartment.
  10. Oct 17, 2011 at 9:48 PM
    KalamaKid
    Oregon
    jack up one front wheel and see if it spins freely. Just spin it with your hands. If it spins your front diff is not locked. Listen to the noise it makes too.
  11. Oct 17, 2011 at 9:49 PM
    KalamaKid
    Oregon
    Check BOTH sides.
  12. Oct 17, 2011 at 9:50 PM
    Chickenmunga
    Keizer, Oregon
    Be right back, sir...
  13. Oct 17, 2011 at 10:03 PM
    Ozziwald
    Ozziwald Well-Known Member
    The tie rod is your steering. The joint of it that connects to your spindle is the tie rod end. If you grab the tie rod and try and wiggle it, the tie rod end shouldn't move around inside the hole it goes into in the spindle. If it does, they need to be replaced. You can also check these by having someone inside your truck moving the steering wheel back and forth and seeing if the tie rod end is moving a little before it starts to move the spindle. If it does, they need to be replaced.
  14. Oct 17, 2011 at 10:12 PM
    all.on.black
    all.on.black Well-Known Member
    Auburn, WA
    06 Double Cab Sport with a few mods
    I can take a look at it for you. You'd have a come up north to Auburn though. You said it makes a squealing noise which would indicate a rotational part. I would guess your wheel bearing might be shot. Does it make more noise taking a left turn or right?
  15. Oct 17, 2011 at 10:29 PM
    TROKITA
    TROKITA Well-Known Member
    Arty
    Utah, the valley
    98 tacoma TRD supercharged
    Supercharged, Custom sunroof, 6 inch lift, wheel spacers, over the rail tire carrier
    i have the same problem on mine but only when i back up from my drive way and not all the time it does that but i think it mite be the bushings on the arms
  16. Oct 17, 2011 at 10:33 PM
    Chickenmunga
    Keizer, Oregon
    Just got back in the house and here's the scoop:
    Jacked up one side at a time with the hi-lift (via the slider). Both do the same thing, all testing was with tires pointed straight:
    -Spinning slowly yields a a rubbery squishing sound from the CV. Imagine walking around in brand new dress shoes. That's the only description that comes to mind
    -I can't visually see any splits in the boot or grease
    -if I spin the wheel like I'm going for big money on the Price is Right, I will get a "TANG" sound. I can reliably make it do this, but I don't have the strength to make it sound more than once before I have to give it the next big spin.
  17. Oct 17, 2011 at 11:00 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
    Its hard to imagine a scenario where both CVs go bad at the same time.
    Does anything change in what you just described if you engage 4hi?
  18. Oct 17, 2011 at 11:10 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    Somethings f'd up in your front diff sounds like.
  19. Oct 17, 2011 at 11:12 PM
    RelentlessFab
    RelentlessFab Eric @Relentless Fab Vendor
    Eric
    Sparks, NV
    07 AC 6mt>03 SR5 >08 Sport and 17 6MT TRD OR
    This is what I was thinking could be going on as well. :cool:
  20. Oct 17, 2011 at 11:17 PM
    all.on.black
    Auburn, WA
    The squishy is normal. That's just the fins rubbing each other on the cv boot.
    Is the the tangy noise only on one side or both? If it's just one side, do you hear the sound more when you turn the steering wheel the opposite direction, while driving?
