Squeak when I acclerate...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ABregenzer, Apr 11, 2012.
  1. Apr 11, 2012 at 7:44 PM
    ABregenzer
    ABregenzer [OP] Fish
    Alex
    The Dirty Lew, TX
    2004 4X4
    Stickers. Lots of stickers.
    Before I start dismantling my truck piece by piece, I figure someone on here would be able to help. :p
    Everytime I push on the gas, I get a squeaking sound coming from my rear wheels. Just started happening today. I've had my tires on for about a month with no issues. I thought it could have been the leaf springs, but it happens when I accelerate or sometimes when I either let off on get on the brake. The sound is noticeable at pretty much all speeds. Is it just my rear drums? Or something worse?
    Thanks, Alex
  2. Apr 11, 2012 at 7:58 PM
    Utard
    Utard Well-Known Member
    Mark
    Tidewater, OR
    2019 Tacoma SR5
    How old are your brakes?
  3. Apr 11, 2012 at 8:01 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    When was the last time that you lubed/greased the leaf spring bushings? The leafsprinvs themselves have friction pads in between each leaf...those pads might need some lube as well.
    :cookiemonster:
  4. Apr 11, 2012 at 8:03 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    One thread is fine. No need to make more.
  5. Apr 11, 2012 at 8:03 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    like dis? really annoying...
  6. Apr 11, 2012 at 8:06 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    Do a few things to isolate the problem:
    Is the sound there if you are in neutral and just rev the engine?
    Any queaking if you bounce the bed up and down?
    Aside from springs and brakes, another thing I've seen in the past in other cars is a broken exhaust pipe hanger. Easy enough to check by crawling under the truck.
  7. Apr 11, 2012 at 8:06 PM
    MonkeyProof
    SoCal- SGV
    David k doesn't get this warning derpity derp :D
  8. Apr 11, 2012 at 8:09 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    :cool:
  9. Apr 11, 2012 at 8:10 PM
    anthony250f
    Anthony
    San Diego, CA
    if you dont hear it when you jump in the bed....im willing to bet its a u joint...same as me
  10. Apr 11, 2012 at 8:14 PM
    MonkeyProof
    SoCal- SGV
    Also...as stupid az it sounds...re-torque the bed bolts, sometimes they work themselves loose and when that happens the bed will move around very slightly making a squeeck noise
  11. Apr 11, 2012 at 8:57 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
    Sorry Chris :eek:
    And it's only when I accelerate. If I coast, there's nothing wrong. I jumped up and down on the bed and nothing. It seems to only happen when the wheels are turning. I personally have never changed the rear brakes but I've only had the truck for a few months and I don't know what all the previous owner did. I haven't had this problem until earlier today.
    Whenever I get into work tomorrow, I'll raise it on a lift and check it out from there.
  12. Apr 11, 2012 at 9:33 PM
    anthony250f
    Anthony
    San Diego, CA
    i had the sameeeeee exats symptoms, minus the turning... and it was the rear u joint
  13. Apr 12, 2012 at 3:20 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
    So I spend $25 on a rear U joint, and I'm working on replacing it. My Dad comes and asks me what's going on. I tell him the whole story about the squeaking and crunching… He then tell me to take the rubber boots out from behind my cab…
    That alleviated some of the squeaking :p
    But I'm still gonna replace that U joint and WD_40 the shit out of my bushings, just to make sure :eek:
  14. Apr 12, 2012 at 3:29 PM
    babytruck
    babytruck Babytruck, babytruck...I've got a babytruck :)
    NorCal
    2010 Barcelona AC 4x4 4.0 6spd
    How embarrassing...:eek:
  15. Apr 12, 2012 at 3:34 PM
    anthony250f
    Anthony
    San Diego, CA
    hahahhahahahahah ohhh my god...i wish mine was thst eazy
  16. Apr 12, 2012 at 3:40 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
    Yeah… :eek:
    BUT, the squeaking is still there… :(
  17. Apr 12, 2012 at 3:44 PM
    babytruck
    NorCal
    Awww mannnn. :(
  18. Apr 12, 2012 at 3:49 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
  19. Apr 12, 2012 at 5:01 PM
    ABregenzer
    Alex
    The Dirty Lew, TX
    2004 4X4
    Silicon sprayed all my bushings on the rear… still squeaking :(
    I'll replace the U joint probably this weekend and fiberglass my bed back together and make sure that isn't the problem either :eek:
  20. Apr 12, 2012 at 5:36 PM
    anthony250f
    Anthony
    San Diego, CA
    my dusk cap was broken on my rear u joint, i wd40/greased and the squeek is gone
