Squeak!!
Discussion in 'Technical Chat' started by sull625, May 30, 2013.
  1. May 30, 2013 at 11:27 PM
    sull625
    sull625 [OP] Well-Known Member
    Dave
    Montana
    12 TRDOR DC Spruce Mica
    I'm new to the forum. I just picked up a 04 Tacoma. Love the truck but noticed an annoying squeak in the front passenger side. It sounds like its coming from a control arm bushing but I'm unsure. Anyone out there have this issue? If so was it the bushings? Thanks for your help!
  2. May 31, 2013 at 12:02 PM
    sull625
    Dave
    Montana
    Any advice would help.
  3. May 31, 2013 at 4:13 PM
    sull625
    Dave
    Montana
    No help here?
  4. May 31, 2013 at 4:15 PM
    thebigsmit
    thebigsmit Well-Known Member
    Brent
    South Carolina
    2013 Tacoma TRD Off Road
    3 inch Toytec lift, Westin E series bull bar, HID/Halo retrofit, sway bar disconnect
    I took my truck to the dealer for the same problem you are describing. When going over a bump the front suspension seems to squeak. It was a radiator bushing.
  5. May 31, 2013 at 5:29 PM
    sull625
    Dave
    Montana
    Radiator bushing? Where is it located? Did you replace or just lube?
  6. May 31, 2013 at 5:38 PM
    thebigsmit
    Brent
    South Carolina
    No idea where it is. They completely replaced it. Should be able to get one from your dealer. Like I said, that was the problem with my truck, yours could be different.
  7. Jun 1, 2013 at 6:35 AM
    sull625
    Dave
    Montana
    True true
