Squeak
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 2015TTDC, Jan 23, 2025.
  1. Jan 23, 2025 at 5:08 PM
    2015TTDC
    2015TTDC [OP] Well-Known Member
    2015 silver TRD Sport Double cab
    Whenever I hit a bump, especially on a turn, I get a squeak coming from the front end. Any thoughts on this? It’s been doing this before & after new shock installation, so that’s not it.
  2. Jan 23, 2025 at 8:17 PM
    wdunnlee
    wdunnlee Well-Known Member
    Will
    Tidewater VA
    2010 Timberland Mica 4x4
    Does it sound like little birds in your engine bay?
  3. Jan 24, 2025 at 11:59 AM
    2015TTDC
    No, you can definitely tell it’s coming from each wheel well area. More so the driver side. I’m going to start with the sway bar links & maybe the sway bar bushings to see if that changes anything. I did notice some grease around the links, as well as my ball joints. They are original (119,000mi)
    Was curious if this was a somewhat common thing with these trucks or if anyone else experienced this…
  4. Jan 24, 2025 at 12:33 PM
    2015WhiteOR
    2015WhiteOR Well-Known Member
    Gainesville TX
    I'd say squeaks in the front suspension are normal for any vehicle with almost 120k miles LOL
    2015TTDC[OP] likes this.
  5. Jan 24, 2025 at 4:29 PM
    wdunnlee
    Will
    Tidewater VA
    Yeah mine started squeaking at 145k
  6. Jan 24, 2025 at 4:42 PM
    wdunnlee
    Will
    Tidewater VA
    I am replacing all the bushings and ball joints with my lift so I’ll let you know if it goes away.
  7. Jan 24, 2025 at 4:48 PM
    2015TTDC
    I plan on doing the same, but when the weather breaks. I’m not doing any of it in 20 degree cold lol. I’m ordering sway bar bushings, sway bar links, and I might get replacement lower ball joints w/ grease zerk
    wdunnlee[QUOTED] likes this.
