Squeakin leaf springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bwood_usmc, Feb 11, 2009.
  1. Feb 11, 2009 at 3:33 PM
    bwood_usmc
    bwood_usmc [OP] Wiskey Tango Foxtrot....
    Ben
    Clayton Ga / Clemson SC
    06 Tacoma TRD Off Road package
    3" Trux Lift, 285-75-R16 BFG All Terrains, K&N Cold Air Intake
    A couple of weeks ago i noticed a small squeaking noise coming from the rear of my truck.... at first i thought that it might be my u joint going bad but that turned out not to be the case..... it progressively got worse until last night i took a whole can of WD-40 to my leafs.... it fixed the prob for now but my question is whats caused this. Is WD-40 going to be a permanant fix? anyone else had a problem with this. Thanks for yalls input
  2. Feb 11, 2009 at 3:35 PM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    try some grease... Search for this topic because I think someone had this same issue a few weeks ago
  3. Feb 11, 2009 at 3:36 PM
    bwood_usmc
    Ben
    I tried white lithium spray greese didnt work to well
  4. Feb 11, 2009 at 3:41 PM
    jdkeller
    jdkeller How many words can be fit in this s
    Jonathan
    Inland Empire, Ca
    2008 Tacoma Prerunner TRD Offroad
    Dome light LED, 6000k HID Headlights and fogs, Grillcraft black mesh, rear 5100's, Total Chaos UCA's, 285/75/16 BFG KM2's, Spidertrax spacers, Blacked out emblems, cb,kenwood tm270 ham radio, All Pro 3" leaf pack, Fox 2.0 coilovers, Revenge Fab Sliders, u bolt flip kit, Pioneer avh4200, bed bar with light and antenna, Wet Okoles, Weathertech Mats, Wet Okole Armrests, Rear KR Fab bumper, bed mat, N-Fab spare tire carrier with full size spare on 16" TRD rim, Bedlinered flares and grille. Camburg Spindles, All Pro front fenders.
    If you cant get rid of it I think you can just take them off and grease them. Ive never done it but I know whenever you add a leaf your supposed to grease it. So maybe throwing some fresh stuff on there will cure it.
  5. Feb 11, 2009 at 3:44 PM
    higherlux
    higherlux Well-Known Member
    Blake
    middle of S.C.
    1998 tacoma 2.7l 4wd/1986 POS
    Mall crawler status
    nope wd-40 will not fix it permantely
    ive tried:(
    you can buy new bushings for ur leavesprings and then grease the hell outta them and that should fix it
    but idk havent triied that yet
  6. Feb 11, 2009 at 3:47 PM
    Lentsnh
    Ok then try new bushings like someone said above me. That will keep them from moving too much.
  7. Feb 11, 2009 at 3:49 PM
    Lentsnh
    instead of using the spray grease get the grease thats in the tube and smear it on your bushings.... Unless that would be a bad idea.
  8. Feb 11, 2009 at 3:49 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    if its the bushings themselves.......you will need to take the bolts out/undo the springs and use some antiseize or a good tacky grease on them.................and if its between the leafs, wash really well with a pressure washer and then try and pack some grease into the springs best you can..................and again, use a good tacky grease.
  9. Feb 11, 2009 at 6:35 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Before takeing anything apart, squirt some brake fluid on the springs. DO NOT GET IT ON ANY PAINTED BODY PARTS. I have been useing it for years, and it has cured any squeeks I have had.
