Squeaking brakes
Discussion in 'Technical Chat' started by Redsox21324, May 30, 2009.
  1. May 30, 2009 at 12:48 PM
    Redsox21324
    Redsox21324 [OP] New Member
    Washington
    08 Tacoma DC LB TRD sport 4x4
    leer 100xq canopy
    Hey I was wondering if anyone can give me some help or advice. My 08 Tacoma DC has squeaky brakes when I'm coming to a stop the softer I press them the more noise they make, the dealership can't seem to find anything or they're just not really looking all thy did was "clean" them once but the next day it was doing the same thing.I bought the truck new and only have put 10,000 miles on it. Any help would be great.
    Thank you
    - Oscar
  2. May 30, 2009 at 8:04 PM
    Simon's Mom
    Judy or Jude :)
    NEK Island Pond VT
    24 Tundra Trd Sport former 13 TRD OR
    Stock for now
    Hi Oscar, welcome to TW!
    As far as the squeaky brakes, do they do in reverse at all? If so there is a brake TSB which will will fix the brake squeak. TSB BR005R-07 SEP 07.
    I had it done to my truck and it fixed it.
  3. Sep 5, 2010 at 1:10 PM
    CrUnKjU!c3
    CrUnKjU!c3 Well-Known Member
    Amit
    Anaheim,CA
    08 Double-cab Prerunner Tacoma
    fiberwerx front and rear baja fenders 6'' bulge.Have 2.5'' lift spacer untill i have enough cash to get LT from camburg. have a tiregate and prerunner bar. Installed a AFE stage II intake. Gearing for 35'' tires.
    how much did the TSB cost?
  4. Sep 5, 2010 at 9:12 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    San Diego (Spring Valley)
    04 Prerunner
    toytec coil spacers, tokicko struts/dubcab springs, energy suspension rack bushings, bilstien hd shocks, K&N FIPK2, Flowmaster 50DF, ScanGuage2, 5000k HID's, horn mod, other stuff that I forgot to list
    Free, if your truck is within warranty :D
  5. Sep 5, 2010 at 11:23 PM
    CrUnKjU!c3
    Amit
    Anaheim,CA
    nah it isnt i got a salvaged truck so no warranty :(
  6. Sep 5, 2010 at 11:38 PM
    tacoma92
    tacoma92 Black Hole Sun
    Forrest
    Gulf Shores, Alabama
    09 SR5 Toyota Tacoma
    I just replaced my brake pads and they said at NAPA that there are certain types of pads that will squeak even though nothing is wrong w them. Lets just say i bought the ones that didnt
  7. Sep 6, 2010 at 3:26 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    Put anti-squeal compound on the back of the pads and anywhere there is metal sliding on metal. Obviously, don't put any on the friction surfaces. Put some on the rotor where it meets the hub. Use a light coat of compound.
  8. Sep 6, 2010 at 7:27 PM
    Barnone
    Barnone Guest
    No, the OPs Taco is under warranty. Take it back to the dealer and make them fix it under the TSB or what ever.
  9. Sep 7, 2010 at 12:45 AM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Just spray the rotors with WD40, that will make them stop squeaking.:D
  10. Sep 8, 2010 at 12:17 AM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    Do your rotors look glazed?
  11. Sep 8, 2010 at 7:20 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Keep on the dealer! This is not normal. Next step for the dealer would be to replace the pads, then either resurface the rotor or replace them. If that doesn't fix it, I'd suspect something in the caliper. If you're under warranty keep on them.....
  12. Sep 8, 2010 at 1:46 PM
    DocBrown86
    DocBrown86 Yota Doc
    Brian
    04 Prerunner
    x2, they will do the brakes under warranty, especially since you have a legit complaint. Just make sure to take a drive with your service writer and reproduce the noise.
  13. Mar 20, 2015 at 10:00 AM
    theJCKRBBT
    theJCKRBBT Well-Known Member
    Paul
    Milwaukee
    2018 DCSB TRD OR, Blazing Blue Pearl
    Boss 2.0 + AAL Lift, NFAB Predator Steps, BFG 265/75 r16 KO2
    great thread, guys. I bought an extended warranty for mine, and would have tried to address this on my own. Good to know this should be covered.
    It's embarrassing to pull up to a stop light at a pedestrian crossing and get looks not because of the truck, but because of the brakes.
  14. Mar 22, 2015 at 8:06 AM
    REDdawn6
    REDdawn6 Well-Known Member
    Redlands CA.
    2011 Tacoma TRD 4x4
    Also , dont forget to lube your bolts holding the calipers on as well.
  15. May 27, 2015 at 1:08 PM
    theJCKRBBT
    Paul
    Milwaukee
    during my routine maintenance for my warranty, I mentioned this to the tech. He told me "It's a Toyota thing. All the brakes squeak a little." I told him that was my fourth Tacoma and none have ever squeaked, and he just shrugged. My only squeek in forward gear, and only between 0-5 mph, though. So at stoplights when people are checking out my truck. :(
  16. Jun 5, 2015 at 3:45 PM
    LSUTaco
    LSUTaco Well-Known Member
    Jax
    11 DC TRD sport
    I have issue with squealing brakes in reverse. It started around 4000 miles after having my rotors resurfaced and brake pads replaced. I inspected the rotors, brake pads, and did a thorough cleaning of in the front discs. I didn't check the drums, but does anyone else have this issue?
  17. Apr 20, 2017 at 7:33 AM
    Rizz
    Rizz Member
    Houston
    08 Tacoma TRD
    Hi, I have been reading this forum, but am new to posting to it.
    My Brakes were recently changed and they squeak (HORRIBLY) when reversing out of my driveway in the morning. Its so loud that people inside the house can hear it, I would equate it to be about as loud as a car horn. I also spoke to the dealership and they said it happens to all Tacoma's. I find that hard to believe since I have been driving various tacoma's since 1990 and this is the first one that has done this. Its a 2013 Access Cab
    I need to find out if this is just normal and i just accept it (which actually means I have to park backwards in the drive way so I dont have to back out of it in the morning to avoid waking everyone up when I leave) or if I keep pushing the dealership (which means I may need help from people in this group to arm myself with data) to make them fix this.
    I am interested to see if anyone else has info on this.
    Thank You
  18. Apr 20, 2017 at 12:09 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Id change the rotors and pads...squeaky brakes are annoying.
