Squeaking clutch repair performed by dealer
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Timbertoy, Oct 11, 2020.
  1. Oct 11, 2020 at 5:08 AM
    Timbertoy
    Timbertoy [OP] Well-Known Member
    Wayne
    2019 Red Tacoma
    I have a 2019 sport with 11 k miles. The clutch started squeaking around 9 k miles. Researched the threads on reasons / repairs performed and brought Tacoma to dealer who greased clutch parts with success for about 1000 miles. Looked deeper into solutions and found an updated TSB ( sorry I don’t have number now) which is a replacement of the master clutch assembly plus assorted parts which has different part numbers so they changed specific items with updated ( hopefully ) non squeaking parts. After it was performed the squeezing is gone but the clutch peddle when depressed only engages when depressed almost to the floor. There is so much play in the clutch that it feels odd. Well back AGAIN to the dealer. I make this note to fellow MT drivers having this repair to make note if having repaired. Hope its just a adjustment.
  2. Oct 11, 2020 at 5:27 AM
    24-7 Well-Known Member
    Phil
    Florida
    16 TRD OR 4Door 6MT
    Driver, KO2's, Open Y-Pipe
    Mine squeaks...... then it will stop....... then it will squeak........ then it will stop. So on and so forth.
    Myles G likes this.
  3. Oct 11, 2020 at 6:21 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Mine is doing it 5k miles ... already had it at the dealer once they lubed it . Noise went away for a week and came back with a vengeance. I have another appointment to get this problem fixed . I hope this doesn’t turn into a weekly dealership visit .i don’t understand why toyota can’t seem to fix a problem that has been well known for years .
  4. Oct 11, 2020 at 6:38 AM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    My 2011 has only been doing it for about 130,000 miles.
  5. Oct 11, 2020 at 8:25 AM
    JaysTRDsport
    JaysTRDsport Well-Known Member
    AJ
    2020 Tacoma Trd sport 4x4 6spd manual
    Toyo off road tires
    All my Tacoma’s never had any Issues including my 2020 6 speed manual shifts fine clutch is Great! I feel it’s more about people not knowing how to use a clutch and ruin it or damage them I bet that is more the Issue than Toyotas fault
  6. Oct 11, 2020 at 9:12 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Get under there and lube the pivot points with Disc Brake Grease, it doesn't melt away.
    GOTSAND?18[QUOTED] likes this.
  7. Oct 11, 2020 at 12:32 PM
    Myles G
    Myles G Well-Known Member
    Myles
    plenty of people have the issue
    some start to hear it at 2k some at 5k and some at 10k some never do. It isn’t the actual clutch so you can’t really F*ck it up. I’ve heard it on my stage 2 clutch and my OEM clutch. I also have a rattle now up top of the squeak. I just don’t mind it anymore my 2nd gen was noisier.
  8. Oct 11, 2020 at 12:48 PM
    GOTSAND?18
    stock
    Your logic doesn’t make any sense . A squeak when pushing in clutch has nothing to do with destroying a clutch . The noise is present when stationary even without shifting into gear . Toyota mechanic confirmed it was coming from the rubber boot that is connected .
    Myles G likes this.
  9. Oct 11, 2020 at 12:56 PM
    Charlie Marlow
    Charlie Marlow Well-Known Member
    Georgia
    19 TRD OR
    I just had the TSB done on my truck. It didn't change anything about the engagement of the clutch that I noticed, but the pedal feels better and tighter.
  10. Oct 11, 2020 at 1:04 PM
    Myles G
    Myles
    When did you have it done? How many miles so far? I’ve heard it’s gotten worse after a couple thousand. Please let me know
  11. Oct 11, 2020 at 1:05 PM
    Charlie Marlow
    Georgia
    19 TRD OR
    They did it just this past week with 15K miles on the truck. We'll see how it goes.
    Myles G likes this.
  12. Oct 11, 2020 at 1:06 PM
    Myles G
    Myles
    Okay try and remember to come back in a month and let us know how it went. I’d really appreciate it.
  13. Oct 11, 2020 at 1:07 PM
    Charlie Marlow
    Georgia
    19 TRD OR
    Yeah, no problem. Mine wasn't squeaking, btw. It was more like a popping or creaking noise as I operated the clutch. It was super noticeable when driving up the parking deck I use for work.
    Myles G likes this.
  14. Oct 11, 2020 at 2:58 PM
    Timbertoy
    Wayne
    2019 Red Tacoma
    The squeak would happen even with Tacoma not running and parked when you depress peddle. The TSB was performed and clutch has slop in peddle. I need to almost fully depress peddle for the catching or point that clutch catches. I just hope the dealer needs to make an adjustment.
