Squeaking from belts?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bambigular, Feb 17, 2009.
  1. Feb 17, 2009 at 9:00 PM
    Bambigular
    Bambigular [OP] Well-Known Member
    Corona, Ca
    04 Double Cab SR5
    I have an 04 V6 with 88K miles. For the last few weeks there has been a squeaking noise coming from what I think are the belts, right around the fan belt area. The noise is consent from idle and when I drive, no matter how fast. The belts look fine no cracks, that I can see. Besides this noise the trucks runs great. Has anyone had this noise?
  2. Feb 17, 2009 at 9:04 PM
    Hambone155
    Hambone155 Well-Known Member
    omaha
    Causing Butthurt is my job
    port and polish intake manifold, supercharger, pulley for charger, lifted, tires, deckplate, (doing full engine build)
    i have that when my belts are running at like 4.5 grand it might be slipping on a pully that could be it.
  3. Feb 17, 2009 at 10:21 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    This could be a couple things.....
    Check all your belts for proper tightness. Fiind an area where the belts are open (no pulleys). Grab each belt with your thumb & finger and twist the belt. If you can twist it PAST PERPENDICULAR - the belt it too loose and needs tightened. You have 3 separate belts to check on the 3.4L.
    OR
    Check your A/C idler pulley. It'll be the belt for the A/C and it goes around a pulley that sits lower than any other pulley. Remove the belt and *feel* the pulley with your hands - if its rough and otherwise doesn't move smoothly and easily, the bearings are probably bad.
