Squeaking from rear end
Discussion in '3rd Gen. Tacomas (2016-2023)' started by GreenTaco02, Oct 17, 2021.
  1. Oct 17, 2021 at 9:31 PM
    GreenTaco02
    GreenTaco02 [OP] New Member
    2021 Tacoma TRD Off-Road 4x4
    Hello everyone I’m fairly new to this and recently bought a Tacoma. So far I have only installed the Eibach Pro Truck Stage 1 Lift with a 1” block.
    I went on some fire roads to try it out and when I got back I noticed some squeaking sounds coming from the rear end. Has anyone ever experienced this? Is it maybe just dirt in the leaf springs or something? Any input would be greatly appreciated.
    Again, I’m new to this but not sure if I should be worried about it since I’m only at 4K miles.
  2. Oct 17, 2021 at 10:31 PM
    .45 Calibear
    .45 Calibear Well-Known Member
    Mount Diablo
    17 TRD Off Road - REI Crawler
    Broverlandering kinds
    Your leaf springs.
  3. Oct 17, 2021 at 11:25 PM
    Stocklocker
    Stocklocker Well-Known Member
    17TRDORDCSBAT
    When your leaf springs get dusty the plastic anti-friction pads between the leaves can start squeaking. It’s super annoying if you have a bad case of it. The problem can be mostly solved by cleaning you leaf springs with a garden hose or pressure washer. It helps if you jack up the rear end of the truck by the frame so the wheels droop and you can clean between the leaves.
    If this does not resolve your issue, spraying some dry graphite lube between the leaves can help.
    https://www.grainger.com/product/CRC-General-Purpose-Lubricant-4JB39
    JoeCOVA and 71tattooguy like this.
  4. Oct 18, 2021 at 5:33 AM
    Cowdog
    Cowdog Well-Known Member
    My 2018 year springs had a squeeking issue which was fixed on a tsb. Maybe the same?
  5. Oct 18, 2021 at 6:35 AM
    Crosbaugh
    Crosbaugh Well-Known Member
    My 7-week old Deavers just started squeaking. Seems to be a universal leaf spring malady
  6. Oct 18, 2021 at 6:42 AM
    jbwardfamily
    jbwardfamily Well-Known Member
    2021 Tacoma SR5 4x4 Double Cab Short Bed
    Had the same after a 2 inch block lift on my '21 on the driver's side. I used some silicone spray in the bushings and between the leafs and it went away. I'm sure it'll be back soon.
  7. Oct 19, 2021 at 10:53 AM
    PAKraig
    PAKraig Well-Known Member
    Kraig
    Central Pennsylvania
    2017 DCSB 4x4 in Silver Sky
    OME suspension and 285/70R17 BFG KO2s
    2017 w/ 1.5" block and add-a-leaf. I hoping to fix mine soon by swapping out the rear suspension with coils and lower control arms, but they'll be installed on a Gladiator :rolleyes:
