Squeaking front end, and warm locking hub
Discussion in '1st Gen. Tacomas (1995-2004)' started by 91Toyotabogger, Apr 3, 2010.
  1. Apr 3, 2010 at 6:14 PM
    91Toyotabogger
    91Toyotabogger [OP] "Loud Tires Can Save Lives"
    North Carolina
    91 4wd 5sp manual Pickup Standard cab white
    Mud Tires, CD player, CB radio with PA speaker, De-badged, window decals, Flow Master 40 series
    When i break i hear a squeak, but i have new pads on them, also when i turn i hear a little squeaking, and my locking hub is warm after a trip down the road, but i just replaced my wheel bearing. What could be causing this? please help me out.
  2. Apr 3, 2010 at 6:23 PM
    Sparky4.0
    Sparky4.0 Well-Known Member
    Aaron
    WestTexas
    01 trd beat to hell
    grease the bearing and pads...
  3. Apr 3, 2010 at 6:25 PM
    91Toyotabogger
    North Carolina
    pads? how you grease that, and when you say grease the bearing you mean under the locking hub cap?
  4. Apr 3, 2010 at 6:29 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    you put brake grease on the back side of the pads.. slide etc. did you install the wheel bearing? if so did you just toss it in or or did you pack the bearing with grease b4 hand?
  5. Apr 3, 2010 at 6:33 PM
    91Toyotabogger
    North Carolina
    a shop put the bearing in and im sure he packed them because he used to work at the Toyota stealership
  6. Apr 3, 2010 at 6:36 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    unless you seen the greased bearing with your own eyes you cant say your sure he greased them.. just cause he worked at a stealership doesnt mean he wont make a mistake... not bashing him or nothing.. but thats where i would start... grease the brakes with anti squeal stuff. and re pack/check the bearing for grease. look inside the lock out see if its dry. http://www.automedia.com/Servicing_Wheel_Bearings/ccr20020901wb/1 http://www.4x4wire.com/toyota/maintenance/front_end/hub_rebuild/
  7. Apr 3, 2010 at 7:10 PM
    91Toyotabogger
    North Carolina
    i just took the cap off the hub and it had grease in it but i added more and i'll see how that goes i mean its a very quite squeak i can barely hear it, but im listening for it and the warm locker is prob normal
  8. Apr 3, 2010 at 7:33 PM
    Sparky4.0
    Aaron
    WestTexas
    01 trd beat to hell
    you not driving with the hub in the lock position are you? that would really cause it to get hot at highway speeds.
  9. Apr 3, 2010 at 7:36 PM
    91Toyotabogger
    North Carolina
    no but i believe the rotor is transferring a little bit of heat to it
