Squeaking front end that can't be tracked down!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JustADummyInATaco, May 16, 2017.
  1. May 16, 2017 at 8:30 PM
    JustADummyInATaco
    JustADummyInATaco [OP] Active Member
    Riley
    UTAH
    06 sr5 driven by noob
    6" Procomp Coilover lift, 18 inch motometal wheels, too small of tires, magnaflow exaust, highly illegal tint, poser TRD off-road stickers, TRD intake, NFAB nerf bars, lots of love.
    So I've had this deep sqeaking creaking noise from my front end for a while now and can't seem to get it to go away. I've got 101k miles, running a 6 inch lift. All my coils and such are good to go, and I just got my rack and pinion system and outer and inner tie rods replaced. Also replaced the strut bushing on my left side. Thought that would fix my issues but nope, still prevalent. I had the truck jacked up the other day for repairs and worked the drivers side upper and lower ball joints and they seemed fine. I don't know where to look at this point. The squeeking comes and goes, but is most present at low speeds when starting off from a dead stop or from turning at low speeds. When the truck Is sitting still, I cannot replicate it by turning the tires or by pressing down on the front end of the truck to compress and decompress the front struts. What the heck should I look for?
  2. May 16, 2017 at 8:31 PM
    Silverspool
    Silverspool Come at me Bro!
    Frank
    DFW
    18T4RORP 17GT350
    Anyone seen my wallet?
    UCA bushings
  3. May 16, 2017 at 8:32 PM
    JustADummyInATaco
    Riley
    UTAH
    Isn't them unless it's the passengers side which I doubt. I worked the drivers side pretty good to remove my cool and it was quiet and smooth.
  4. May 16, 2017 at 9:01 PM
    Rosscopeeko
    Rosscopeeko Well-Known Member
    BC
    08 DC LB 4x4 sport
    I'd say the LCA bushings as well. My truck had an annoying squeak that would come and go. Everything seemed tight. I installed my home 884 springs and went in for an alignment and learned that my LCA bushings were seized to my alignment cam bolts. I replaced everything and the squeak was gone.
  5. May 17, 2017 at 12:41 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I agree. Squeaking and creaking in the front end at low speed is very typical of upper and / or lower control arm bushings.
  6. May 17, 2017 at 12:57 AM
    09BlueBeast
    09BlueBeast Well-Known Member
    Cody
    Denver
    09 Speedway Blue TRD Sport 4x4
    Check your radiator mount bolts
  7. May 17, 2017 at 1:13 AM
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    Remove entire front suspension, then drive around. If it doesn't squeak anymore, it's the suspension. If it still squeaks, then you know it's something else :D
    Stemmy and Silverspool like this.
  8. May 17, 2017 at 1:39 AM
    09BlueBeast
    Cody
    Denver
    You joke but I was at that point trying to find my squeak... and am pretty much there now trying to get this fucking thing to drive straight without feeling like I'm going to die
  9. May 17, 2017 at 1:41 AM
    bullaculla
    Da big big island!
    Yeah, I've had a few bad squeaks, groans, and clunks I had a hard time tracking down. I actually had my wife drive my truck back and forth over smooth concrete with me under the truck holding on to crossmembers getting dragged while trying to listen for it. Believe me, I know that feel bro.
  10. May 17, 2017 at 3:46 AM
    justdoit
    justdoit Well-Known Member
    Colorado Springs
    22' 4x4 AC TRD Off-Road
    Hood posts, the 4 contact points.
  11. May 17, 2017 at 5:19 AM
    Justanotherhemi
    Justanotherhemi Space Cowboy/Ninja
    Rick James
    Area 52 (because area 51 was full)
    Intelligent Life Exists
    I had an annoying squeak that could not be fixed with suspension part swap. It turned out to be the bushings for the core support on the passenger side had worn through the rubber and was rubbing metal on metal. Hope it helps
  12. May 17, 2017 at 5:30 AM
    techride
    techride Weekend Warrior
    Stuart
    British Columbia
    2014 DCLB v6 4x4
    Bilstein/Icon 2" suspension lift with wheelers 5 leaf springs, 7-pin relocate through bumper, bfg KO2s, redline hood struts, immryo mirror relocation, stubby antenna, dipped emblem, heated mirrors, Jason trek cap, led fogs, debadged
    Lube sway bar bushings?
