Squeaking in Reverse
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PhillyTaco18, Jul 10, 2013.
  1. Jul 10, 2013 at 5:22 AM
    PhillyTaco18
    PhillyTaco18 [OP] Well-Known Member
    Jeremy
    Philadelphia,MS
    07 PreRunner Lifted
    2.5 Spacer on Front, 1.5 AAL with Pro-Comp shocks on rear.
    I'm getting the squeaking noise when I put the truck in reverse, but not when I go forward. Usually in the mornings. If I have the windows down it sounds like it is coming from under the truck but I am not 100% on that. From reading some other threads it seems like my u joints and bearings need to be greased or worse (replaced). I drive a prerunner and I read that only the 4x4's have the grease fittings for the gun. What is the best suggestions for greasing these?
  2. Jul 10, 2013 at 6:11 AM
    nimrod712
    nimrod712 Well-Known Member
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Is it a rotational squeak, or does it just squeak as you start moving? (if that makes any sense..)
    As for the U-joints, just get under the truck and see if you have grease fittings. If not, the best way to grease them is replace them with greasable U-joints. I guess you could take them out, grease them, and put them back in, but what the crap would be the point of that?
  3. Jul 10, 2013 at 6:15 AM
    PhillyTaco18
    Jeremy
    Philadelphia,MS
    07 PreRunner Lifted
    It's most definitely a rotational squeak. Like I said it will only do it in reverse. Doesn't make a peep when going forward.
  4. Jul 10, 2013 at 6:24 AM
    Toy Yoda
    Toy Yoda gotta make sure Youtube comes down to tape this
    Garrett
    06 DCLB
    OME, ARB, Warn, Snugtop XV
    mine did that too, then later happened when in drive, check your U joints, mine were broken at the rear diff, you might want to invest in the CB drop too if you're lifted
  5. Jul 10, 2013 at 6:48 AM
    PhillyTaco18
    Jeremy
    Philadelphia,MS
    07 PreRunner Lifted
    I'm lifted 2.5 in the front and 1.5 in the back. 2wd. Think I need the CB drop?
  6. Jul 10, 2013 at 11:16 AM
    nimrod712
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    I wouldn't fool with the drop, axle shims, or any of that unless you're having vibes. Just check your U-joints.
  7. Jul 10, 2013 at 11:20 AM
    PhillyTaco18
    Jeremy
    Philadelphia,MS
    07 PreRunner Lifted
    I'm just going to get the u joints replaced. I'm almost at 130k. It's just time. Think I should go ahead and have the center bearing done while I'm at it?
  8. Jul 10, 2013 at 11:38 AM
    nimrod712
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    I probably would since you'll already have the driveshaft apart. The Dorman carrier bearings seem to be okay and are only like $40.
  9. Jul 10, 2013 at 11:39 AM
    DR007
    DR007 Well-Known Member
    Dylan
    Port Barre, LA
    '06 DCSB PreRunner
    MagnaFlow exhaust, K&N cold air intake, MB TKO wheels with 265/75/r16 Hankook Dynapro ATM, Blue Center shift LED color change, Map Lights with Dome, LED Map and Dome lights, Cluster Light Change, DTRL, Parking Light as Blinker, Blue A/C Control lights, Blue Clock, Bed Lights, Debadged tailgate, painted all exterior plastic trim, 6LZ Lightbars in grille, OTRATTW switches, Fog Light in Reverse light Mod, LED Blinkers all around, Projector Fog Lights, 15" blitzpro light bar, added hidden cig lighter port, custom plate front bumper, OME complete lift with 885 front coils, Ultraguage, CB radio 3' whips, 12v bed lighter port, Center Console Lights, AllProOffroad Sliders, 50" roof led light bar, 2 BlitzPro 6LZ Reverse Lights
    Its the Toyota Squeak. I think they all have it... all thats we've owned (6)
  10. Jul 10, 2013 at 11:41 AM
    Toy Yoda
    Garrett
    06 DCLB
    i kept breaking u joint because of my lift, which is larger than yours, but the CB drop eliminated all problems.
  11. Jul 10, 2013 at 11:47 AM
    nimrod712
    Jonathan
    Hot Springs, AR
    '08 Taco TRD
    Yeah, but the drop works on some and makes others worse. It all depends on the setup. The only way to really tell is by measuring the angles.
  12. Jul 10, 2013 at 12:40 PM
    PhillyTaco18
    Jeremy
    Philadelphia,MS
    07 PreRunner Lifted
    I ordered the OME CB drop from Wheelersoffroad.com just to see if it helps. Can't hurt for $12.00
  13. Jul 19, 2013 at 9:15 AM
    PhillyTaco18
    Jeremy
    Philadelphia,MS
    07 PreRunner Lifted
    Just replaced all three u-joints today with Moog 354 greasables. A local auto repair shop only charged me $65.00 to install them. No brainer.
