Squeaking in the rear
Discussion in '1st Gen. Tacomas (1995-2004)' started by maconhurler, Nov 18, 2009.
  1. Nov 18, 2009 at 6:15 AM
    maconhurler
    maconhurler [OP] Well-Known Member
    Harrisonburg, VA
    04 4wd v6 sr5
    Deckplate Mod, Catz Fog lights, Roll Top Tonneau Cover, Pioneer Premier 800prs HU, 10" Kicker L7, Kicker 5 1/4 components, Polk dB 5x7s, Oznium superflux puddle lights and bed lights
    Need a little help here. I've got a squeaking in the rear of the truck when I back up on unlevel ground. Feels like the truck is rocking side-to-side a little bit. Would this be a frame thing, a suspension, or leaf spring thing? Any ideas would be helpful, the sound is loud enough where people turn their heads to look and is insanely annoying. My truck deserves better.
    Thanks.
  2. Nov 18, 2009 at 6:17 AM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    is the noise only when you back up on unleveled ground or just when the truck moves in general. you could have some squeaky leafs
  3. Nov 18, 2009 at 6:17 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    I would say if your truck is rocking back and forth that bad you have bad shocks. They could also be the cause of the squeak.
  4. Nov 18, 2009 at 6:18 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    Leafs. Clean them out good and lube them up.
  5. Nov 18, 2009 at 6:19 AM
    Afwrestler1986
    Johnstown, NY
    How long does your truck continue to rock when you jump off of the rear bumper?
  6. Nov 18, 2009 at 6:22 AM
    FARNORCAL
    FARNORCAL Well-Known Member
    06 Tacoma4x4 DC LB Silver TRD Sport
    SEE BUILD
    Yep its probably the leafs almost positive i had the same problem with my 03 prerunner. Clean them the best you can then use a spray on lube. It may take a couple times but itll go away. Have your buddy push up and down on the rear bumper and pin point where the sound it coming from.
  7. Nov 18, 2009 at 6:27 AM
    CJH9980
    CJH9980 Well-Known Member
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    5100's, Eibach springs, Toytec AAL, Total Chaos UCA's, MetalMiller Skid
    I had that on my tsb leafs when they were only 4 months old. Fixed it with WD-40, no problems since.
  8. Nov 18, 2009 at 6:28 AM
    maconhurler
    Harrisonburg, VA
    04 4wd v6 sr5
    Any recommendations on best way to clean them....wire brush? or just a good scrub with soap and water? Is there a specific lube spray I need to look into?
    Thanks for the help guys, this problem will hopefully be remedied this weekend.
  9. Nov 18, 2009 at 6:30 AM
    Afwrestler1986
    Johnstown, NY
    Just use a pressure washer to clean them out good and wd-40 if it still squeeks.
  10. Nov 18, 2009 at 6:30 AM
    maconhurler
    Harrisonburg, VA
    04 4wd v6 sr5
    The rocking does not seem excessive. And yes, it is only when backing on unlevel ground. Level ground, driving forward, etc I hear no noise.
  11. Nov 18, 2009 at 7:01 AM
    CJH9980
    Clint
    Shreveport, LA
    2010 TRD OR 4x4
    I had a friend pushing down on the bumper while I listened to isolate the sound. Hope that helps
  12. Nov 18, 2009 at 8:29 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    Has anyone tried Fluid Film on them? I've never tried it, but it is very widely used in the Lawn/Landscaping industry. I think it acts similar to having a Teflon coating on whatever you put it on.
