Squeaking like a bag of mice
Discussion in '1st Gen. Tacomas (1995-2004)' started by conrad ashworth, Nov 17, 2009.
  1. Nov 17, 2009 at 8:03 AM
    conrad ashworth
    conrad ashworth [OP] New Member
    conrad
    saskatoon sk
    03 PreRunner TRD
    Last week I noticed a squeak coming from the back of my 2003 PreRunner TRD. Happens when I accelerate and continues until it's a faint high pitch squeal at full speed, probably because I can't hear it for wind noise then seems to dissapear. It also is noticeable when I slowly brake to a stop where its a slow dull squeak, completely speed related. You don't hear it if you coast or ride the brake. It's most noticeable during accelerations from stop though or accelerating from low speed. Its almost as if something sounds dry or rubbing together. I've had several people stand on the sidewalk and driven by them and had several suggestions from suspension to U joints. Its very loud in parkades or other enclosed areas or when driving beside buildings where you get the sound deflection from the structure. If i could be under the truck and drive it at the same time I could probably figure it out but there's only one of me so that won't work....any suggestions before I make an appointment and wait 3 weeks to get in or do more damage? Ive been driving it very gently till I figure out what it is. Thanks for any responses. :confused: Awesome truck otherwise, still get LOTS of compliments on it or people asking if its for sale :D
  2. Nov 17, 2009 at 8:12 AM
    KeithB
    KeithB Well-Known Member
    Keith
    Cheshire, CT
    SWB '09 Tacoma DCSB Sport 4x4
    Wheels and Tires: 17x8" Ultra Goliath wheels with P285/70R17 Nitto Terra Grappler G2, Suspension: Icon coilovers set at 2.5", TC UCA's, 1.5" lift 3 leaf pack with overload left in, 3* shims, carrier bearing drop, Bilstein 5100 B110 rear shocks Other: TRD SS exhaust, Pioneer AVIC 4100 H/U with Android Auto (awesomeness), sat radio bluetooth, Accessories: Toyota roof rack, black Toyota running board steps, cargo divider, weathertech floor liners, Literider roll up soft tonneau, thule bars over tonneau Cosmetic: window tint, grillcraft black mesh upper/lower grill, eyelids, tinted tails and third brake light, vinyl armrest in doors and center console Lighting: fogs only mod, bed lights in pockets, back up lights, amber interior accent lighting, amber 10" LED light bar in hood scoop, 33" LED bar behind the lower grill, amber lamin-x on fog lights
    my '01 did the same thing. It was the u-joint by the pinion.
  3. Nov 17, 2009 at 9:16 AM
    conrad ashworth
    conrad
    saskatoon sk
    03 PreRunner TRD
  4. Nov 17, 2009 at 11:34 AM
    Shel
    Shel New Member
    Sheldon
    San Marcos, CA
    2002 Silver 4x4 DBCB TRD V6
    Wet Okoles: Full Gray with Black piping. Bilstein HD 4600's.
    Wow!! This is exactly what my '02 is doing. I hear it best when taking off, or coming to a stop. And parking lots next to buildings are the worst.
    I have an appointment Thursday with Toyota to try and find the problem. I had it in once, and they said they couldn't hear it. Now I can go armed with some information as to what is most likely causing it.
    Thanks a ton for posting this, and the great video. :)
  5. Nov 17, 2009 at 1:10 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Definintly sounds like a U joint if you know how, crawl underneath (after blocking your tires) & grab your drive shaft near to where the u joints are & move the shaft looking/feeling for side to side movement, if you feel barely any at all , U joint is probably bad, fairly easy to replace & not too expensive, hope this helps & good luck.....:cool:
    P.S. U joints usually wear out a little quicker with a manual trans as opposed to automatics.
  6. Nov 17, 2009 at 6:13 PM
    HondaGM
    HondaGM Roll Tide
    James
    South-Pole
    09 DC 4x4 Blown Honda VTEC V8
    trd exhaust,step bars,vent visors,bed lights,tailgate mod
    ck carrier bearing
  7. Apr 18, 2016 at 3:58 PM
    jaredguidry
    jaredguidry New Member
    Prerunner
    What did it end up being? My truck is doing the same thing and the video is no longer available
  8. Apr 18, 2016 at 4:12 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I thought about that but theres so much indiscrimitive slop in CB's by nature ..
