Squeaking noise 15' Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by John4x4, Jul 20, 2015.
  1. Jul 20, 2015 at 6:31 PM
    John4x4
    John4x4 [OP] Active Member
    Bucks County, Pennsylvania
    2015 DCSB 4x4 V6
    2.25 inch procomp leveling kit
    So everytime i go over a speed bump or when I'm on a ruff road my back driver side squeaks. But when I'm on a smooth road it's fine.. Any advice wd40 shock or? Any advice is appreciated!
  2. Jul 20, 2015 at 6:35 PM
    MattScatt28
    MattScatt28 2017 Seattle Mariners AL West Champs!
    Snoqualmie
    Leaf springs?
  3. Jul 20, 2015 at 6:43 PM
    John4x4
    2015 DCSB 4x4 V6
    What about them could they also be the cause ?
  4. Jul 20, 2015 at 6:44 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    My 2015 leafs squeak
  5. Jul 20, 2015 at 6:57 PM
    John4x4
    2015 DCSB 4x4 V6
    Man that's kinda bullshit if there's not a easy fix like really Toyota 6,400 miles and only started about 400 miles ago . Makes me want to go and tell someone about it at the dealership
  6. Jul 20, 2015 at 6:57 PM
    kpla51
    kpla51 Well-Known Member
    Fort Campbell
    I thought all trucks squeak when bushings get wet. My jeep use to squeak after cleaning and then after off roading a bunch it would stop. Every truck Ive owned has squeaked in the rear suspension at some point.
  7. Jul 20, 2015 at 7:00 PM
    John4x4
    2015 DCSB 4x4 V6
    Hmm might be on to something I did noticed it after I washed my truck but didn't think to connect the dots.
  8. Jul 20, 2015 at 7:03 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    squeaky leaf springs... its common, you will get used to it, no harm to the truck.
    If you are really picky you can search the "squeaky leaf fix"
  9. Jul 20, 2015 at 7:07 PM
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    Already come to terms with it. Will be replacing them anyway with some other leafs
  10. Jul 20, 2015 at 7:42 PM
    Cape Codder
    Cape Codder Native Son
    Jack
    Hangin' Out in the Atlantic
    2010 TRD Sport 4x4 Access Cab 4.0L V6 Auto - Silverstreak Mica
    SOS Concepts Sliders waiting for POR-15 Rust Abatement (Spring 2016), OEM Silver Tube Steps 'til then OME 2.5" Suspension w/885 Coils & Dakars / LR UCA's w/SpecRide Bushings / Lifetime Alignment Wheeler's "Super Bump" Bump Stops Front & Rear / OME Carrier Bearing Drop / 2.5° Axle Shims (Eliminated Vibration) Moog Greaseable LCA Cam Bolts / ToyTech Sway Bar Relocate Kit / Stainless Steel Extended Brake Lines (Front & Rear) TIRES - LT275/70R17 (32.2") Firestone Destination A/T's (and Matching Spare) mounted on (5) 17”x8” (4.5” BS) Machined Aluminum Alloy, with Light Gunmetal Accents, Konig SixShooter Wheels with Hofmann Anthracite Adhesive Power Weights / McGard 65002 Chrome SplineDrive Lug Nuts / Cloned Schraeder EZ Sensor 33000 TPMS SNOW TIRES - Bridgestone Blizzak DM-V1 - P255/75-17 (32.1") mounted on Stock TRD Sport Wheels (5.5” BS) w/BORA 1" Wheel Spacers (to = 4.5” BS), Wheels Locks & OEM Lug Nuts Wheel Master 36" Stainless Steel Mesh Spare Tire Inflator/Checker attached to Rear Bumper / Spare Tire Lock TRD Skid Plate / Husky Mud Flaps / Redline Tuning Hood Struts / UltraGauge / Frame Hole Plugs / OEM Chrome Exhaust Tip Salex SLX102 - '05-'13 Tacoma GloveBox & Console Organizers Combo Set / GRID-IT (Console Cover Organizer) Color Matched SATOSHI Grill w/ Individual Letters Toyota Emblem (from ‘86 Toyota Land Cruiser) Hella Fogs on Elusive Elements Light Bar mounted behind Grill / Relocated Horns & Outside Temperature Sensor SilverStar zXe Headlights / SilverStar Fogs / Upper & Lower Color Matched Eyelids / LED's @ Dome, Maps, Lic Plate & 3rd Brake / 866 Foglight Lamps for Back-Up Lights WeatherTech Headlight & Foglight Protection / AutoBahnd RoadBlock (3M) Paint Protection System on Front End & Tailgate Avid Hitch Step Color Match Powdercoated / Avid LightBar Color Match Powdercoated / DIY Front Plate Holder mounted on AVID Light Bar (NO Bumper Holes) Emblems DeBadged / CBoy808's Silver OME EMU, Medium Gray Mall Rated, TRD Skid & Matte Black US Flag Decals SockMonkey Medium Gray Shadow Only Bedside, Door, Hood Scoop & Tailgate Decals DeBadged Leer 100LX Cap w/ Adventure Pkg including Thule 48” & 60” AeroBar Locking Removable Racks, Removable Front Window & Rear Door Remote Lock Charcoal/Blk Wet Okoles (front & rear) w/Front Seat Back Waterproof Zippered Pockets, Front Pistol Pockets & Seat Heaters / Drop Stop Seat Wedge Fillers 6 CD Changer w/SubWoofer (TRD Sport OEM) / BluLogic Hands Free (Blue Tooth) / Lutron Maestro Pico Remote Control for Driveway Floods Pro-Fit & Pro-Clip Device Holders for Cell Phone & GPS / Beltronics RX 65 Blue Detector / Garmin 885T GPS 30% Tint on Driver/Passenger Windows / WeatherTech Dark Front Window Deflectors / AutoMate AM-7 Alarm w/Remote Start WeatherTech FloorLiners (Front & Rear) / WeatherTech All Weather Mats (Over Front Liners) TRD "Offroad" Front Recovery Hook (Color Matched) / 2" x 30' & 3" x 30' Recovery Straps ELITE OffRoad 2" Receiver Hitch Shackle / Daystar Black Shackle Isolator / LifeLong Locks Class 5 Locking Hitch Pin Viair 00088 88P Portable Air Compressor / Rockford 12,000mah, 200/400 Amp, Portable Power Source & Mini Jump Starter Pop&Lock PL5305 Manual Tailgate Lock w/Color Matched Handle / Driver's Door Keytechniques Keyhole Cover OEM Bed Mat / 4 Extra Military Issue Bed "D" Rings Attached with Bed Bolts / 4 Extra Bed Rail Tiedowns & 2 Mini Tiedowns H3R Performance Halguard Halotron® 1 (Clean Agent) - HG250C 2.5lb Chrome Fire Extinguisher and Extreme Duty Quick Release Bracket (Mounted in Bed) H3R Performance Halguard Halotron® 1 (Clean Agent) - HG100C 1.4lb Chrome Fire Extinguisher (In Cab Back Door Pocket) H3R Performance MX500R - 5lb Dry Chemical Fire Extinguisher w/ Vehicle Mount (On Cab Back Floor, Not Yet Mounted in Bed) ResQMe GB0-RQMTWIN-O Orange Keychain Version of the Original LifeHammer (Hanging Within Reach in Cab) FogLight Anytime / Differential Breather / A/C Condensate Drain / Tailgate Hoseclamp Anti-Theft Mods Toyota Extra Care Platinum Vehicle Service Agreement (VSA) – 8 Year / 125,000 Miles TSB's: Transmission TSB / Blower Motor TSB / Steering Intermediate Shaft Bushing TSB 90L Accelerator Pedal D0L Recall / Driver & Passenger Seat Belts Recall / Inspect Wheels & Tires "BOB" Recall The “TW EMPTY UR WALLET MOD” and a Pile of Stuff Waitin' for Install
    Fix for my Squeaky Dakars
    More in my Gallery
    CC
  11. Jul 20, 2015 at 10:18 PM
    fixer5000
    fixer5000 the logical one
    massachusetts
    2018 4runner limited in nautical blue
    cut those wire ties flush. those will give you one nasty cut. imagine raking your forearm up against that !!
    Alfred and shakerhood like this.
  12. Jul 20, 2015 at 10:31 PM
    nextfriday
    nextfriday Well-Known Member
    Indianapolis, IN
    13 SR5 Double Cab
    5100s@2.5", 2" aal Leer 100 XR w/ Yakima rails and towers 18x9 Pro Comp Rockwells Cooper Discoverer AT3 275 65 18
    Spray some fluid film on the ends of the leafs that have pads
  13. Jul 21, 2015 at 3:01 PM
    Cape Codder
    Jack
    @fixer5000
    Good call there, Steve.
    But Never, ever, EVER, cut off a cable tie, even with flush cutting dikes.
    It will still leave a dangerous sharp edge
    Always, ALWAYS, Twist and Spin it off with the flat end of a pair of pliers.
    And as you may or may not know, there's even a tool to do it automatically.
    Do as I say, not as I do. :D
    The pic below, taken around the same time, shows that the Twisted Cable Tie,
    stretches and curls, leaving only smooth plastic.
    A bonus to this method is, that it may even tighten the Tie a notch or two.
    The Cable Ties on the Leaf Springs were installed on a cold, wet day.
    I couldn't get my pliers in, as I recall, without dropping the spare,
    and negotiating the shackle to get to a couple of 'em.
    All cuts are pointed in towards the spare, in a tight area, I'm well aware of them, and they're on the list.
    Hopefully, you pointing this out (and your genuine concern for my welfare),
    will be seen by and educate others, who won't have to experience it, to learn.
    I posted those pics in the "Squeaky Dakars" Thread, and never gave it a thought.
    So now, with you in mind, I'm going back to edit that post, with the warning.
    That being said, My Leaf Springs Still Don't Squeak. :bananadance:
    Thanks for your post :thumbsup:, seriously.
    CC
    stbear and John4x4[OP] like this.
  14. Jul 21, 2015 at 7:02 PM
    John4x4
    2015 DCSB 4x4 V6
    Thanks for all the info and pictures I may try!
  15. Oct 12, 2015 at 11:48 AM
    Newbie11
    Newbie11 New Member
    This was probably already answered, but it's a problem with the rear leaf springs. I bought my '15 Tacoma (4dr, 4x4) TRD OffRoad brand new in March, 2015. The squeaks started occurring at around September (approximately 10k miles on the truck). I brought it to the dealership to have them diagnose the problem. Servicer told me that Toyota has been informed of the problem (and that certain trucks with this problem been recalled), except they don't have a fix for it yet...go figure. I was told to check back in a couple weeks.
  16. Oct 19, 2015 at 6:35 AM
    trd1221
    trd1221 Well-Known Member
    Jeremy
    2015 White Tacoma TRD Sport
    Bed cover, tailgate lock
    I have 2015 with under 5000 miles and toyota is completely replaceing my leaf springs on both sides. I will see if that works if not my truck falls under FL lemon law.
  17. Oct 19, 2015 at 6:59 AM
    -dustin
    -dustin Well-Known Member
    Leander, TX
    2020SWDCSBTRDPROFTW
    unrelated, and referring to something older, but I prefer fingernail clippers or a sharp razor for cutting zipties. Fingernail clippers (the big kind) leave a nice, rounded (small) edge. Razor will cut it flush, but might slip and mark something (like a clean paint job...).
    How are leafs still a problem. My 99 did that shit. only got 2500 on my 15 so far...
  18. Oct 19, 2015 at 7:06 AM
    trd1221
    Jeremy
    Leafs are a big problem in the taco community includeing the recall for 07 to 11 tacos and mine are squeak uncontrollable and Toyota said they are common on 2015 amd my Dad's 2015 tundra is having similar problems
