Squeaking noise from wheel well when going over bumps
Discussion in '3rd Gen. Tacomas (2016-2023)' started by zooyorkajd, Sep 25, 2021.
  1. Sep 25, 2021 at 6:36 AM
    zooyorkajd
    zooyorkajd [OP] Well-Known Member
    High pitch squeaking noise coming from wheel well when going over bumps. Truck has 36k miles. Stock everything SR5 except trd pro wheels. Comes from drivers side only from what I’ve noticed.
  2. Sep 25, 2021 at 6:50 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Look in the wheel well and look for rubbing. If it is all stock except the Pro wheels, it shouldn't be rubbing, but worth a look. Turn the wheel in the direction you hear the noise and put the tire up on the curb and check.
    Did the noise start after the rim change? What size tires? Stock?
  3. Sep 25, 2021 at 6:52 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Could be so many things. Literally dozens of things could be squeaking.
  4. Sep 25, 2021 at 7:27 AM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Leaf springs ?….maybe
    wilcam47 likes this.
  5. Sep 25, 2021 at 8:44 AM
    zoo truck
    zoo truck Well-Known Member
    2020 quicksand sr5 tacoma
    None
    Could be bushings?
  6. Sep 25, 2021 at 8:55 AM
    supmet
    supmet Well-Known Member
    Paul
    Rancho Cucamonga, CA
    2019 White TRD OR 4x4
    Have a fat friend jump in the bed while you look for what's squeaking
    Dontkillzenkis and wilcam47 like this.
  7. Sep 25, 2021 at 9:08 AM
    zooyorkajd
    its coming from the drivers front wheel well. I have potholes in the area so I’m sure that something got messed up from that
  8. Sep 25, 2021 at 11:37 AM
    Toyota09
    Toyota09 Well-Known Member
    2016 Tacoma TRD Off-Road Inferno
    Look at and inspect your cv axle, sway bar bushings, ball joints upper and lower. How does your shock look? Sounds like you have something loose or a bushing is going. Can you replicate the sound by pushing on the front of the truck or rocking the truck? Is your battery mounted down tight? The sound could be echoing in the wheel well so I would also check your engine bay
    Get some lithium grease and start spraying bushings. My leafs get bad sometimes even when the truck is clean and I spray some of this in there and it stays silent for a very long time before I have to do it again
  9. Sep 25, 2021 at 12:35 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    Are the sr5 and pro wheels using the same offset? As in when the tire goes up and down the tire is not rubbing on the control arm or spring?
  10. Sep 25, 2021 at 1:21 PM
    NorNev
    NorNev Phone? Call someone who gives a shit.
    Dave
    39° 31′ 6″ N, 119° 59′ 19″ W
    KDMAX Tuned 17 2•2X2•2 Hood Scoop
    A Few
    Take it out wheeling. Solves everything :mudding:
    Chuck X1 and AmateurTaco1313 like this.
  11. Jun 25, 2023 at 6:05 AM
    AustinPaowers
    AustinPaowers Member
    Winnipeg MB
    2020 DCLB 4x4
    Eibach Pro lift SCS BR6 17x9 -38 295 70 17 JBA UCA TRD SKID PLATE DIODE DYNAMICS FOGS
    Did you ever figure out what it was? I have the same issue lol
  12. Aug 24, 2024 at 1:16 PM
    Skint Ripley
    Skint Ripley New Member
    2022 white Toyota Tacoma SR5
    Check your skid plate!
    I have an SR5 Tacoma with 36k miles and a bolt on the passenger side of my skid plate was loose, giving it some play and making an awful squeak! Hope this helps!
