squeaking noise front end :(
Discussion in '1st Gen. Tacomas (1995-2004)' started by Wyatt_tacoman, Feb 4, 2019.
  1. Feb 4, 2019 at 6:50 PM
    Wyatt_tacoman
    Wyatt_tacoman [OP] Member
    Wyatt
    99 taco 2.4l 5spd
    well i got a squeaking noise coming from the front left drivers side. it makes the noise when i turn the wheel when stoped and when im moving. it also makes it when i hit bumps any one know what it could be i kinna think its the lower ball joint but any more info will help
    GQ7227 likes this.
  2. Feb 4, 2019 at 7:02 PM
    thenodnarb
    thenodnarb Well-Known Member
    California
    2001 TRD 4x4 379k and counting
    could be lower control arm bushings. all 1st gens will need them by now if they haven't already been done, regardless of miles. i just did mine. took me a couple weekends to do myself because i was missing some crucial tools i had to buy. probably cheaper to buy complete replacement control arms if you don't like buying tools.
    GQ7227 and Running Board Man like this.
  3. Feb 4, 2019 at 7:03 PM
    tcjacado
    tcjacado Well-Known Member
    Sounds like the power steering pump, if it's doing it while stopped turning the wheel.
    Or if it's doing while rolling then probably a wheel bearing.
    GQ7227 likes this.
  4. Feb 4, 2019 at 7:18 PM
    Wyatt_tacoman
    Wyatt
    99 taco 2.4l 5spd
    it dos it both time will moving and stoped. and if i push down on the hood (bouncing it up and down it dos it really bad) and the engine isnt running @JaCado
  5. Feb 4, 2019 at 7:20 PM
    tcjacado
    Upper and lower control arms bushings or maybe even the sway bar, or ball joints. Get the front end up on a Jack and some stands. Start moving stuff around that goes up and down.
  6. Feb 4, 2019 at 7:21 PM
    rollin904
    rollin904 Feather Slinger
    TJ
    Greenville, SC
    '14 DCSB 4x4
    Grease that hood latch just in case
    tcjacado likes this.
  7. Feb 4, 2019 at 8:11 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    I bet it's the upper ball joints. Mine were squeaking really bad when I came back from a particularly muddy wheeling trip, they made a terrible groaning squeak/creak noise when turning the wheel. I felt a hole in the rubber boot on the backside so I shoved a water hose in there, flushed all the dirt out and then took a bunch of grease and packed it into the boot through the hole. The squeak went away and hasn't come back. I don't plan to replace until I hit 200k which is 13k miles from now. I did both sides this way.
    GQ7227 likes this.
  8. May 2, 2019 at 5:50 PM
    benrozencranzrocks
    benrozencranzrocks New Member
    99 tachoma
    Yes , my ball joint broke after 240K whole wheel disabled obviously . Lucky I was going slow. The driver side was replaced 4 years ago. It is now squeaking, I sprayed it with lithum lube in a can, didn't help. Should I replace it or any other suggestions, It visually appears ok.
  9. May 3, 2019 at 6:42 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    did you use aftermarket part?
    GQ7227 likes this.
  10. May 3, 2019 at 7:41 AM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    mine are like that now.. I need to get them changed soon
  11. May 8, 2019 at 6:19 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    did you check the TW obituary page?
  12. May 8, 2019 at 7:48 AM
    GQ7227
    GQ7227 mw survivor
    J A Y
    i am sure there are dead and totaled trucks out there getting parted out and maybe need to get a memorial page
    Running Board Man likes this.
