SQUEAKING NOISE WHEN CAR IS MOVING
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPilot2004, Feb 17, 2011.
  1. Feb 17, 2011 at 7:15 PM
    TacomaPilot2004
    TacomaPilot2004 [OP] Active Member
    Miami, FL
    2004 Tacoma V6 4x4 Crewcab
    Hey everyone,
    I have a 2004 Tacoma V6 automatic 4x4 double cab. I just started noticing a squeaking noise coming from the left side of the car. I'm not 100% sure if its the front or back, but I think it's coming from the front.
    It happens when the car is rolling, with or without the engine on. I can be in Drive and hear it, or I can start moving, power off the car in neutral, and still hear it.
    I checked around the tires for anything obvious but didn't see anything. Does anyone have any idea what this could be??
    Any help is appreciated!!! :)
  2. Feb 17, 2011 at 7:19 PM
    Max-4_Yota
    Max-4_Yota The Welfare Cadilac
    Michael
    South Carolina
    04 Tacoma 4x4, V6, 5spd
    Squattin'
    Probably time for some new front brake pads.
  3. Jun 6, 2012 at 6:49 AM
    dswilder
    dswilder New Member
    Nashville Tennessee
    04 Toyota sr5 Tacoma 4x4
    You may have fixed this already; however, I have a 2004 Toyota 4x4 V6 as well and had the same thing. It took 3 trips to the shop to find out that Toyota had a bad batch of wheel bearing seals and water would get in and rust them out. Once this was discovered and replaced it stopped. It was the rear right. I thought orginally it was a bad u joint but it was the wheel bearings. I hope this helps.
  4. Jun 6, 2012 at 12:07 PM
    MowTaco
    MowTaco Well-Known Member
    Kansas
    16 Chevrolet Silverado
    My brakes squealed when the front pads needed replacing. It was really weird they would squeak going down the road but as soon as I tapped the brakes it went away. I figured there was no way it could be bad brake pads but sure enough it was. It'll be obvious if you jack it up and take off the wheel you think it's coming from. On mine the squeaker was just coming in contact with the edge of the rotor and had a groove worn in it from this. That'd be the first thing I recommend you check.
  5. Jun 6, 2012 at 12:08 PM
    XXXX
    XXXX Well-Known Member
    sKiP
    05 Prius
    You drive a truck...not a car OP.
  6. Jun 6, 2012 at 12:09 PM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Maybe...maybe not....it is over a year old....
    NECROPOST!!
  7. Jun 6, 2012 at 12:29 PM
    MowTaco
    Kansas
    Dammit I never pay attention to the original dates before I post.
    In the words of Charles Barkley: "I'm a dumbass"
