Squeaking noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by toytaco85, Oct 16, 2009.
  1. Oct 16, 2009 at 10:57 AM
    toytaco85
    toytaco85 [OP] Well-Known Member
    Arizona
    96' 4x4 single cab
    ive had a squeak coming from (im assuming) my front shocks. any time i go over a speed bump or a dip in the road its squeaks. ive read a couple times on here that if your shocks are blown they will bounce 3 or 4 times before stabilizing. mine dont do that. is there anything i can do aboutt he squeak, or are mine blown too?
  2. Oct 16, 2009 at 11:03 AM
    NraFan
    NraFan Join the NRA! Protect your freedom!
    JT
    SoCal
    2011 Sienna LE, rockin the mini van!
    Power sliding doors baby! WooHoo!
    Maybe its a mouse? :notsure: Try the cheese mod.
  3. Oct 16, 2009 at 11:07 AM
    Afwrestler1986
    Afwrestler1986 Well-Known Member
    Johnstown, NY
    01 trd 4X4 ex cab manual
    Gray wire, Some lights in the bed area, and some character marks throughout.
    You sure it's from the front?
  4. Oct 16, 2009 at 11:12 AM
    toytaco85
    Arizona
    96' 4x4 single cab
    im almost positive. when i get out of my drive way, i dont hear the aqueak when the rear tires hit the pavement, but the front tires do it everytime......
  5. Oct 16, 2009 at 11:17 AM
    Afwrestler1986
    Johnstown, NY
    evrey now and then my leaf packs get mud or dirt and they squeak, try hosing the leafs off real good and see if that helps.
  6. Oct 16, 2009 at 11:18 AM
    stucksucksnayota
    stucksucksnayota Well-Known Member
    Barry
    Fort Smith, Arkansas
    14 Taco 4x4 TRD Sport DCSB
    OEM roof rack, Shorty antenna (eBay), soft tonneau cover, K&N drop in air filter, bed mat, interior LED lights, 5100's, MT tires to come soon!!!
    I know my rear leaf springs squeak all the time. But if your sure its in the front could be some worn out bushings.
  7. Oct 16, 2009 at 11:19 AM
    toytaco85
    Arizona
    96' 4x4 single cab
    i dont have leafs up front...
  8. Oct 16, 2009 at 11:22 AM
    Afwrestler1986
    Johnstown, NY
    i know, the rears. just because your truck squeaks when you fronts hit the pavement doesn't mean the rear of the truck doesn't move.
  9. Oct 16, 2009 at 11:35 AM
    toytaco85
    Arizona
    96' 4x4 single cab
    well i was under the back of my truck when i washed it last week, and there wasnt anything that i could see going on. the bushings...? little rubber piece at the top of the shock?
  10. Oct 16, 2009 at 12:18 PM
    Afwrestler1986
    Johnstown, NY
    try some lube on the leaf shackle. or spray the whole pack. if its the front I am not sure what it would be. but it sounds like what mine did. if i backed out straight it usually wouldn't squeak, but if i turned the wheel while backing out it made the rear leaf packs squeak.
  11. Oct 16, 2009 at 12:32 PM
    98tacoma27
    Ben
    Not Beech Creek
    Walk around your truck and push down on each corner of the bumpers. That is all you need to do to locate the squeak. If it is in the rear, then you probably hae rust or dirt inbetween the leafs. If it is in the front, then you probably have dirt in the coil assembly or it may need grease.
