Squeaking nosie coming from the serpentine belt pulley system area
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Woodruff0842, Apr 10, 2025.
  1. Apr 10, 2025 at 12:57 PM
    Woodruff0842
    Woodruff0842 [OP] New Member
    Jacob
    2019 toyota tacoma trd off road
    Hey so my serpentine belt snapped on me and I replaced the belt . But after I replaced the belt i started to get a cherping/squealing nosie when I'd start the truck and while I was driving. Sounds like upper idler pulley was going out so I replaced it . But I'm still getting the squealing nosie and I can't locate where its coming from. Any ideas? My ps pump pulley has some front to back play but idk if it's going out or not. I had a video but I can't upload it
  2. Apr 10, 2025 at 4:57 PM
    TacoLin1234
    TacoLin1234 Well-Known Member
    Lance
    Sutherlin, OR
    2020 TRD Sport
    Maybe check belt tension and tighten if necessary?
    kahanabob likes this.
  3. Apr 10, 2025 at 5:23 PM
    betrayus
    betrayus Milk steak connoisseur
    Denver, CO
    2021 SR5 DCSB 4x4 AT (MGM)
    Stock
    If you drip some water on the belt, does the squeaking stop temporarily?
  4. Apr 10, 2025 at 5:26 PM
    Woodruff0842
    Jacob
    I'm not sure i haven't done that . But it dose still squeal when it's raining . I put some belt conditioner on the belt today tho , and it sounded like it got worse for bit
  5. Apr 10, 2025 at 6:35 PM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Are you sure the new belt is the correct part number and length? If it didn't squeak with the old belt I'd try another brand.
    TS4x4 likes this.
  6. Apr 10, 2025 at 6:44 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    A@!#$@$%#$%
    The wild west
    2016 SR5 DCSB
    Why would rain make a difference? It shouldn't be raining on your engine.
  7. Apr 10, 2025 at 6:47 PM
    Rusty66
    Rusty66 Ain’t Afraid
    Rhode Island
    19' Limited 4x4 (01' TRD OR, 97’ SR5 V6, 88’ SR5 Extra Cab)
    Spraying a serp belt with any belt dressing will end that belt. Is it chirping or squealing?
  8. Apr 10, 2025 at 6:52 PM
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    2 big questions as replacing an engine belt is not like replacing a light bulb
    1 did you replace the belt with an oem or cheap out with aftermarket
    2 not to insult but do/did you know how to properly install with correct tension
