Squeaking Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Blaze1404, Nov 8, 2010.
  1. Nov 8, 2010 at 7:15 PM
    Blaze1404
    Blaze1404 [OP] Member
    Florida
    2007 Toyota Tacoma Prerunner
    Dual-Exahust-K&N Cold Air Intake
    The past couple of days I have notice a horrendous squeaking noise coming from what sound directly under my truck, in the center. Can't quite pin-point it. Has anybody else had this problem. Any help would be appreciated-thanks. I work on my truck a lot but this has me baffled, I've checked everything.
  2. Nov 8, 2010 at 7:17 PM
    airsoft_warrior
    airsoft_warrior Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    Is it when the A/C or heat is on? If so try using the search button up top!! But really if it is then take it to the dealer they will replace it if it is under warranty... (It might help if I explain why lol) The A/C or Heat motor squeaks at times when it is turned on. so if that is it the factory may replace it. Try a search and see what you come up with if you havent yet.
  3. Nov 8, 2010 at 7:19 PM
    TACK
    TACK Well-Known Member
    Nevada
    10 PreRunner TRD Off-Road MGM
    Bilstein 5100s at 1.75", Level 8 Tracker wheels, Sickspeed shift knob, mud flap delete, white lithium grease mod for creaky clutch pedal
    Do you have the manual tranny?
  4. Nov 8, 2010 at 8:38 PM
    zeroendless
    zeroendless Well-Known Member
    Dallas, TX
    Stock
