Squeaking rear springs
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PA452, Jun 16, 2010.
  1. Jun 16, 2010 at 12:24 PM
    PA452
    PA452 [OP] Well-Known Member
    Western PA
    15 Access TRD Offroad, V6, 5spd Auto, 4x4
    Anyone else have rear springs that make a lot of noise? Every time I start out from a stop I can hear it loud and clear. They do the same on the move, I just can't hear it as well.
    I'm working with stock rear leafs and out of warranty for the TSB. Don't know that that would make the difference anyway?
  2. Jun 16, 2010 at 12:29 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    isnt there a tsb for the leaf divider pads too?
  3. Jun 16, 2010 at 12:31 PM
    YotaDan
    YotaDan Dan
    Dan
    Oregon
    Jack the vehicle up so the rear suspension is hanging, get a can of HD silicone spray, and soak the bushings really good. Then, grease in between each leaf in the pack, mostly at the ends of each leaf where the most pressure is. you may need to pry the leafs apart just a bit to get the grease in there.
  4. Jun 16, 2010 at 12:32 PM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Boulder, CO
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    Here you go, check post #7
  5. Jun 16, 2010 at 12:57 PM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    Did the same thing when mine were squeaking. It has been about a month or so since I did and I haven't had a squeak since.
  6. Jun 16, 2010 at 4:58 PM
    beachbumberry
    beachbumberry Well-Known Member
    andrew
    fl now, tx native
    05 sr5 4x4 access cab
    leveling kit, american racing rims, push bar, nerf bars
  7. Jun 16, 2010 at 6:59 PM
    PA452
    Western PA
