Squeaking sound coming from my rear?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MikeyD, Aug 21, 2009.
  1. Aug 21, 2009 at 2:24 PM
    MikeyD
    MikeyD [OP] Well-Known Member
    Sayreville NJ
    2007 Toyota tacoma 4x4
    BHLM, HID kit, yellow fogs, Grill craft, Hellas behind grillcraft, LED cup holder mod, after market horn, extra reverse lights, under body glow for off roading at night, pro comp 7089's wrapped in 255/75/17 bfg mud terrains, Toytec coiovers sat at 3.25, 2" add a leaf with 5100's, Satoshi grill mod
    The past few weeks my rear end has been squeaking really loud and its kind of annoying and embarrassing. How can i get this sound to go away?
  2. Aug 21, 2009 at 2:27 PM
    LostRebel
    LostRebel Well-Known Member
    Almost Canada, USA
    Black Access Cab 4x4 TRD Off Road
    Fisher plow, BakFlip and Snugtop cap, Demello Sliders, Scanguage,
  3. Aug 21, 2009 at 2:32 PM
    bwood_usmc
    bwood_usmc Wiskey Tango Foxtrot....
    Ben
    Clayton Ga / Clemson SC
    06 Tacoma TRD Off Road package
    3" Trux Lift, 285-75-R16 BFG All Terrains, K&N Cold Air Intake
    Im assuming that you are talkin about your leaf springs squeaking which seems to be a common problem.... mine was the same way and was cured by jacking up my truck to take all the pressure off the springs..... pressure wash in between them real good and spray some lubricating spary of some sort in between them...... you can take a flat head screwdriver and spead the springs apart..... be sure to cover the entire silencing pad with the spray..... this is what i did and solved the problem...... hope it helps
    edit: i forgot to add.... i used liquid wrench lubricating spary.... worked like a charm
  4. Aug 21, 2009 at 2:39 PM
    MikeyD
    Sayreville NJ
    Thanks alot i appreciate it. Im so happy their is a solution to this annoying sound.
  5. Aug 21, 2009 at 2:57 PM
    bwood_usmc
    Ben
    No problem dude..... i suggest you dont use WD-40.... it seems not to work as well
  6. Aug 21, 2009 at 3:09 PM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    I just let mine break in.
    After I got the AALs installed it was sqeaking like a dump truck..
    It's better now but still squeaks on occasion.
  7. Aug 21, 2009 at 3:10 PM
    MyToyTaco
    MyToyTaco ╒╪╕
    Nick
    Port Hueneme
    15 Ram EcoDiesel
    put some subs in your truck!
    I haven't been able to stop mine from squeaking, only minimize it. sucks.
  8. Aug 21, 2009 at 3:10 PM
    gupster88
    gupster88 Well-Known Member
    Brett
    Almost Heaven
    '17 Inferno DCSB O/R
    STOCK 4 NOW
    power wash the leaf springs then spray white lithium grease from auto zone or advance auto on them. ive found that the white lithium grease lasts longer than wd-40
  9. Aug 21, 2009 at 3:12 PM
    bwood_usmc
    Ben
    Yeah but it turns everything white.....
  10. Aug 21, 2009 at 4:05 PM
    pmo
    pmo Well-Known Member
    Nova Scotia Canada
    2007 Tacoma 4x4, DC, 6 Speed Manual.
    Silicon spray....any autoparts store has it. Works great
