SQUEAKING SOUND FRONT LEFT TIRE ON 2004 V6 4X4 DOUBLE CAB...PLEASE HELP!!
Discussion in '1st Gen. Tacomas (1995-2004)' started by TacomaPilot2004, Sep 12, 2011.
  1. Sep 12, 2011 at 6:41 AM
    TacomaPilot2004
    TacomaPilot2004 [OP] Active Member
    Miami, FL
    2004 Tacoma V6 4x4 Crewcab
    Hi everyone,
    I have a 2004 Tacoma V6 4x4 Double Cab. I've recently started hearing a squeaking noise and it appears to be coming from the front driver's side wheel. It ALMOST sounds like the noise you hear when your brake pads need replacement. I am sure it's not that because I replaced the pads about 3 or 4 months ago.
    The really strange thing is that it happens when I hit a slight bump. It will start squealing and it will keep squealing until I hit another bump and then it stops. If I am driving with smooth terrain, there will be no problem until I hit a slight bump which starts it again. It sounds like a squealing/grinding/rubbing noise. I used to hear it only with the window open, but now I can even hear it with the windows closed.
    I have no idea what it could be. Please help!!! :)
  2. Sep 12, 2011 at 12:15 PM
    jbrandt
    jbrandt Well-Known Member
    Sacramento, CA
    '04 TRD Tacoma 4x4 DC
    King ext travel coils Total Chaos UCAs Sticker mod
    Is it all the time, or just under braking, or what??
    how soon after you replaced the pads did this start? Your anti-vibration clip or something similar might be rubbing.
    Either that or you might have a bad wheel bearing.
  3. Sep 12, 2011 at 12:17 PM
    Yoytoda
    Yoytoda The Little Truck That Could
    Roland
    Big Bear,CA / Upstate NY(Saratoga)
    2010 Tacoma Regular Cab 4x4
    completely stock
    maybe the front rotor dirt shield
  4. Jul 28, 2012 at 8:00 AM
    tweeek
    tweeek Well-Known Member
    Victoria, BC
    2006 Tacoma Access Cab TRD OR
    Did you ever solve this? I am experiencing the exact same issue. Squeaking is consistent while driving, and does not disappear while breaking.
  5. Jul 28, 2012 at 9:31 AM
    04v6trd
    04v6trd Well-Known Member
    tylor
    port moody
    silver double cab ted
    my started doing the same thing about 2 weeks ago, but now my passenger side is slowly starting to do it :S
  6. Aug 27, 2012 at 7:38 PM
    03TacoWJB
    03TacoWJB Well-Known Member
    03 Access Cab SR5
    my just started to do the same thing to what did yall do
  7. Aug 28, 2012 at 9:55 AM
    TacomaPilot2004
    Miami, FL
    Wait, sorry, I just posted but re-read my own initial post.
    I still do hear a slight jingle when I go over bumps, but I guess I've become so used to it that it no longer bothers me and I really don't hear it.
    I'm pretty sure it's the anti-squeeze clamp thing that rattles around, because it has come loose before. I THINK, but I'm not sure....Honestly, it's been so long I can't even really remember what it was, but I know I couldn't find out and was not able to do anything about it.
    I'm not sure what it was, but it seemed to work itself out. Sorry, I know that's not much help.
  8. Aug 28, 2012 at 10:54 AM
    MRBOND101
    MRBOND101 TTE
    Dylan
    Frisco, Texas
    16 TRD-OR AC
    Its either yall's pads arent fully releasing against the rotor, or you have a bad caliper that needs to be replaced. Same thing was happening to my truck about a week ago. Took both front tires off replaced pads, and calipers no more squealing, or noise of any sort. Also changed out the brake fluid. May even be the rotor itself and needs to be turned. Hope everything works out well for everyone! Nothing worse than having the loudest squealing vehicle when coming to a stoplight at an intersection, and everybody turns to look at you. :eek:
