squeaking sound
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Stricker 2016 4x4, Sep 14, 2016.
  1. Sep 14, 2016 at 6:22 AM
    Stricker 2016 4x4
    Stricker 2016 4x4 [OP] Well-Known Member
    2016 Tacoma SR5 4x4
    I just got my first oil change buy toyota last week and ever seance then their is a squeaking sound comeing from the pasanger side of my engine it almost sound like the fan belt pull would make! I can only hear it when Ideling and goes away when I excel rate any body else have this noise or an idea of what it might be?
  2. Sep 14, 2016 at 8:24 AM
    Riding Dirty
    Riding Dirty Sinner; saved by grace
    Before: '16 TRD OR 4x4 AC QS//After: 17 T4R Pro 040
    PlastiDip
    Might be a cab mount bushing. I think I have one going bad. It intermittently squeaks, especially in high heat. Gonna get it checked out soon. Some others have had body cab mount bushings replaced for this issue.
  3. Sep 14, 2016 at 8:08 PM
    Stricker 2016 4x4
    2016 Tacoma SR5 4x4
    Mine starts makeing the sound as soon as I crank it up but I can only hear it if the windows are down and the radio is not on I wouldn't mind toyota looking at it but the just say we don't hear anything but I'll look in to them mounts
  4. Sep 14, 2016 at 8:10 PM
    Lawfarin
    Lawfarin Who me?
    Beetle Juice
    NY
    2024 GMC Sierra
    https://youtu.be/L9AjtT08XLQ
    Sound like this? There was a post on this
  5. Sep 14, 2016 at 8:16 PM
    2016_dbag
    2016_dbag Well-Known Member
    2016 POSTURD
    Damn, how does he have zero scratches on his dash display cover? Maybe it's because he didn't take off all the stickers inside.
  6. Sep 14, 2016 at 8:21 PM
    flatus
    flatus Well-Known Member
    biloxi,ms
    2020 TRD OR DCSB 4wd Auto
    Waiting for bank account to grow
    I have this same sound. I had a tech listen to it a couple of days ago. He told me it is a normal sound. He said it is a noise caused during the injector cleaning cycle. He said Toyota put out an info bulletin about it.
  7. Sep 14, 2016 at 8:31 PM
    MT48
    MT48 Well-Known Member
    Parker CO
    Took my truck in for this as mine has progressively gotten worse (louder). I was told this is a normal sound from the high pressure fuel pump. I am trying to get options from Toyota for a fix.
    From the service notes:
    "CONFIRMED THE CUSTOMERS CONCERN. THERE IS AN INHERENT HIGH PITCHED NOISE COMING FROM THE HIGH PRESSURE FUEL PUMP LOCATED NEAR THE PASSENGER SIDE FIRE WALL. CONFIRMED WITH THE SHOP FOREMAN THAT THIS IS A NORMAL CHARACTERISTIC OF THIS FUEL PUMP."
  8. Sep 15, 2016 at 6:53 AM
    Stricker 2016 4x4
    2016 Tacoma SR5 4x4
    I read the comment on that video and someone said that they had the same problem and they asked if they used shell gass and something to that affect and said that this could cause the problem and I have used she'll gass the past two time I've filled up and I don't ever rember hearing the knoise befor I put shell gass in my truck so the next time I feel up I'll get what I was useing befor to see if it's still makeing the same knoise.. And I don't always believe what toyota says they just probely don't feel like dealing with it.
  9. Sep 15, 2016 at 11:55 PM
    TacoFister
    TacoFister Well-Known Member
    Josh
    2016 QS TRD 4x4 Off Road
    Get the high pressure fuel pump changed out. End of story...
    Mush Mouse likes this.
  10. Sep 16, 2016 at 7:06 AM
    Stricker 2016 4x4
    2016 Tacoma SR5 4x4
    Do you know we're it located on the truck
  11. Sep 16, 2016 at 7:08 AM
    YDCtaco
    YDCtaco Well-Known Member
    Alexandria, VA
    2016 DCSB TRD OR 4x4-Auto
  12. Sep 16, 2016 at 9:39 AM
    TacoFister
    Josh
    Like the intake manifold section. Have the dealership change it out, warranty stuff. Took me 2 different dealers to get one to find the problem and order the part
  13. Sep 16, 2016 at 12:14 PM
    TacoFister
    Josh
    Also. If the pump is making the noise when you pull up to the dealer, leave the truck running so they can hear it.
  14. Sep 16, 2016 at 12:16 PM
    greeneggsnspam
    greeneggsnspam ಠ_ಠ
    Houston, TX
    .gif
    Too poor to list anything interesting.
  15. Sep 17, 2016 at 6:06 AM
    Stricker 2016 4x4
    2016 Tacoma SR5 4x4
    Thanks for the help
    TacoFister[QUOTED] likes this.
