Squeaking Tacoma (Driveshaft?)
Discussion in '1st Gen. Tacomas (1995-2004)' started by MagicalBacon, Jun 2, 2023.
  1. Jun 2, 2023 at 5:11 AM
    MagicalBacon
    MagicalBacon [OP] Active Member
    Michael
    SoCal
    2013 Toyota Tacoma Regular Cab 4x4 2.7L
    Hello everyone! Been a long time lurker, but haven’t had anything much to post about my tacoma. I have a 2003 Tacoma PreRunner 4CYL Regular Cab Automatic. Everything has been great with it, except for one issue. Whenever I go over about 20 MPH, I start to hear a squeaky sound come from underneath the truck. It doesn’t sound like it’s coming from the engine. When I apply acceleration the sound ceases. But anything over 20, with my foot off the gas, I hear a squeak. One remedy I found was greasing the Zurg joints underneath on the drive shaft but it only lasts so long. The sound is accentuated especially if it’s cold outside. Any suggestions anyone might have would help!:)
  2. Jun 2, 2023 at 5:35 AM
    Clearwater Bill
    Billy
    Largo Florida
    Search the term 'leaf spring squeak'.
    While that might not be your problem, it takes minimal effort to experiment and see if the noise stops. If it does, you can move to a more permanent solution.
    MagicalBacon[OP] and MalinoisDad like this.
  3. Jun 2, 2023 at 7:07 AM
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I was also going to suggest checking your leaf packs for 1. tightness and 2. not being overly dirty.
    Mine squeak when they flex if they’re dirty. Hose them down and they’re quiet for a good while.
    MagicalBacon[OP] and ztwatson like this.
  4. Jun 2, 2023 at 9:33 AM
    ztwatson
    ztwatson Well-Known Member
    Milwaukee, WI
    2004 Tacoma TRD Xtra Cab
    Interesting. I've been hearing a squeak from the rest for a while and my leaf springs are covered in road dust and gravel.
    MagicalBacon[OP] likes this.
  5. Jun 2, 2023 at 9:37 AM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    Does it squeak at very low speeds in reverse? But based on what you already said it sounds like your u-joints are bad. Have you ever had the driveline rebuilt/u-joints replaced?
  6. Jun 2, 2023 at 9:45 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    U joints, wheel bearings, diff (pnion and diff bearings) - in that order.
  7. Jun 2, 2023 at 5:56 PM
    MagicalBacon
    Michael
    SoCal
    I bought the truck when it had about 189k on the clock, brought it up to 209k. The previous owner kept an extensive history of replacements and maintenance but I don't see a single thing about the replacement of the u-joints or driveline. I will definitely check that out with my local mechanic, as I am not that mechanical savvy.
  8. Jun 2, 2023 at 5:57 PM
    MagicalBacon
    Michael
    SoCal
    I will check those out as well! Thank you so much!
  9. Jun 2, 2023 at 5:58 PM
    MagicalBacon
    Michael
    SoCal
    I tried what you said and while reversing at low speeds it does not squeak, I forgot to mention that
