Squeaking under the hood at 2000+ RPM
Discussion in '3rd Gen. Tacomas (2016-2023)' started by greg8765, May 9, 2019.
  1. May 9, 2019 at 3:20 PM
    greg8765
    greg8765 [OP] Well-Known Member
    Greg
    Utah
    2023 Tacoma TRD Off-Road
    Tuff Country Lift, Smart Cap, Tint, Pop & Lock, Door Sill Decals, Rooftop Tent
    My truck has started to develop a what I'd refer to as a consistent chirping noise when going over 2000 RPM. Almost sounds like it's coming from the left of the engine, but can't tell. It's been happening every few days for the last three weeks.
    Any thoughts?
  2. May 9, 2019 at 3:24 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    If it sounds like crickets chirping it is the High Pressure Fuel Pump
  3. May 9, 2019 at 9:22 PM
    greg8765
    Greg
    Utah
    as i listened to it tonight, it was more of a whine than chirping.
  4. May 9, 2019 at 9:38 PM
    shakerhood
    Southern Ohio
    Or this too?
    whatstcp likes this.
  5. May 9, 2019 at 11:15 PM
    tacoturdpro
    tacoturdpro Well-Known Member
    2017 White Tacoma TRD Pro 6MT
  6. May 9, 2019 at 11:20 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Maybe he's talking about diff whine.
  7. May 10, 2019 at 8:23 AM
    Samurai Tech
    Samurai Tech Well-Known Member
    2017 Tacoma SR5 Dbl Cab 4X2
    Chirping noise is high pressure fuel pump. There is a TSB issued for that concern. I had mine replaced and no chirp since then, although dealer did not want to do at first since it was not chirping when they had the vehicle. My logic is if a customer complains of a certain issue and there is a TSB issued for that specific issue, perform TSB.
    shakerhood likes this.
  8. May 10, 2019 at 8:27 AM
    Comb
    Comb Known Member
    2017 TRD Sport 4x4 DCSB 6MT BBP ABCDEFG
    OVTune Verified Purchase
    Your logic is sound. Dealer logic is more "if a customer complains about something, then it must be a normal characteristic of the vehicle."
  9. May 10, 2019 at 8:27 AM
    Cutter_
    Cutter_ I probably could have googled this
    2002 Super Air Nautique Build
    Old Man Emu lift, 2 10" JL subs
    Probably the cat that crawled in there
  10. May 10, 2019 at 10:04 AM
    Zoop
    Zoop Well-Known Member
  11. May 10, 2019 at 11:52 AM
    greg8765
    Greg
    Utah
    thanks for the videos, it's definitely not that. it only happens when i'm going over 2000 RPMs. it sounds pretty bad
    Zoop likes this.
  12. May 10, 2019 at 11:55 AM
    Zoop
    Check your serpentine belt and pulleys for abnormal wear maybe
  13. Apr 16, 2023 at 6:28 PM
    keaweamahi
    keaweamahi New Member
    2018 tacoma sport
    did you figure out what it was? My tacoma has the exact same problem.
  14. Apr 16, 2023 at 7:32 PM
    SandyTaco4x4
    SandyTaco4x4 Well-Known Member
    Southern CA
    17 DCSB/AT QS TRD Sport 4x4
    There is a TSB out for the serpentine belt in early model 3rd gens. Didnt fix my issue tho my 2017 goes through a belt a year
