Squeaking while backing up?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Romo7493, Jun 25, 2014.
  1. Jun 25, 2014 at 12:11 PM
    Romo7493
    Romo7493 [OP] Active Member
    Media, PA
    2016 TRD OR DCSB Black
    Lately I've noticed a squeak coming from somewhere in the back of the truck whenever I have it in reverse. It sounds like its maybe coming from the rear wheels or somewhere under the bed. It sounds like a squeaky wheel to be honest but I know that doesn't make sense because it is not happening in drive. It is only in reverse at low speeds. It just got inspected Friday. I asked them to check it out and they shrugged it off but it passed. Anyone else have this issue and is this something I should be concerned about? Truck is a 2010 AC 4x4 sport with 80k miles.
  2. Jun 25, 2014 at 12:15 PM
    cquester5
    cquester5 Well-Known Member
    2014 Tacoma TRD Sport
    Squeaking while moving slowly? Could very well be a bad U-joint.
  3. Jun 25, 2014 at 12:29 PM
    robbytaco
    robbytaco Well-Known Member
    Rob
    San Antonio
    06 DC TRD Sport
    Most likely u joint, probably the rear one at the back axle. I just replaced mine about a week ago.
  4. Jun 25, 2014 at 12:46 PM
    478DblSport
    478DblSport Thermonuclear Protection
    Byron, GA
    07 Silver Streak Mica PreRunner DC TRD Sport
    | EXTERIOR | DiamondBack SE Tonneau Cover, Havoc HS2 Hoop Steps, Tailgate Hose Clamp Mod, Shortened OEM Antenna, DeeZee Bed Mat | INTERIOR | Flyzeye V2W (Amber/White/Amber), RAM Mt A-Pillar Mod, Audio: Pioneer AVH-X5700, PDX-5 (119Wx4+410W), Polk Audio MM6501 (F) & MM651 (R), JL Audio CP108LG-W3v3 (Sub), w/Monster, Rockford, & Streetwire cabling, Metra Dash Kit.
    Yep, I'd guess U-Joints. On mine the squeak was rhythmic with how fast I was backing up. So with mine being a Prerunner the original U-Joints didn't have zerk fittings so I replaced them with ones that did.
  5. Jun 25, 2014 at 1:12 PM
    Romo7493
    Media, PA
    Thanks guys that was a quick answer. After doing a search on U joints it sounds like thats what I got. Its also been rumbling a little at low speeds between like 10-20 on acceleration which sounds like another sympton. Gonna call the mechanic and see about getting it replaced.
  6. Jun 25, 2014 at 2:02 PM
    robbytaco
    Rob
    San Antonio
    06 DC TRD Sport
    While it's parked with the shifter in neutral, you can crawl under and move the driveshaft. Try and rotate it a little back and forth at the u joints and you should be able to tell by either the squeak or how much play is in the u joint which one is bad.
