Squeaking
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1982ace, Sep 12, 2013.
  1. Sep 12, 2013 at 4:22 PM
    1982ace
    1982ace [OP] Active Member
    South Ga
    22 Tacoma sr
    Loud squeaking from leaf spring shackles I think ,anybody else had this problem
  2. Sep 12, 2013 at 4:27 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Replace bushings, i would soak them all down with pb blaster or wd40 and make sure thats whats squeaking. You can order poly bushings from wheelers off road.
  3. Sep 12, 2013 at 5:05 PM
    1982ace
    South Ga
    22 Tacoma sr
    Thanks, toying with the idea of just fixing that or going with a lift. Suspension is pretty wore out from previous owner pulling heavy loads
  4. Sep 12, 2013 at 5:15 PM
    MTgirl
    Weesa
    Bob's secret mod lair
    Yes, this is the only stuff that has ever worked for me. Rinse the leaf springs down really good with a power washer. Let them dry then spray this on the bushings and at each of the friction pads between the plys of the leaf packs. It lasts about 3 or 4 months depending on your driving habits and conditions.
  5. Sep 12, 2013 at 5:19 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    if you have confidently narrowed the squeak down to the shackles them I would get new bushings or new grease-able shackles..
    but lets be honest here..... LIFT IT!!! :cool:
