Squeaky 2013 4x4 solved
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MLG, Oct 3, 2013.
  1. Oct 3, 2013 at 8:39 AM
    MLG
    MLG [OP] New Member
    Missouri
    Tacoma 4x4
    I had looked and had dealer look for cause of a squeak for months. Finally the dealer found the cause. Not in suspension ... but the hood was mis-adjusted ... once they adjusted the rubber spacers and latch ... no more squeak!!!
    Hope this helps someone else if they have the same problem:):rolleyes:
  2. Oct 3, 2013 at 8:41 AM
    Large
    Large Red
    Could you explain the squeak? Most people's squeaks come from the rear leaves.
  3. Oct 3, 2013 at 1:53 PM
    TxFireman
    TxFireman Factory Pilot
    San Antonio, Texas
    2013 DC-SB TRD-OR, tow package, entune/nav
    Probably the rubber adjustments you can find on the underside of the hood. Most often, American makers have them on the top of the radiator support. They are for stabilizing the hood corners, since the hood mostly rides on the latch that holds it down. They are near the front corners of the hood. If his were making contact, without actually providing some tension, then it's possible they could be vibrating against the core support and squeaking. At least I suspect that's what he's talking about.
  4. Oct 4, 2013 at 8:00 AM
    MLG
    MLG [OP] New Member
    Missouri
    Tacoma 4x4
    They said it was the rubber supports mis adjusted.
  5. Oct 4, 2013 at 8:03 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    my rear leafs squeak like a bitch... so I just turn up the radio louder ;)
