Squeaky 2016 toyota tacoma sr5
Discussion in '3rd Gen. Tacomas (2016+)' started by Nickburton2017, Jul 10, 2017.
  1. Jul 10, 2017 at 11:59 PM
    Nickburton2017
    Nickburton2017 [OP] New Member
    Nick
    2016 Tacoma sr5 2wd
    My new 2016 toyoa tacoma sr5 2wd is squeaking very bad. I only drive it on the highway and in the neighborhood. Ive takenit in 3 eperate times and he sevice manager has told me it is a common problem that all they can do it was it with a rag and water! Does anyoneelse have this problem? If you do take ot in we need 55k people to make the comlaint before they recall the truck and have the parts fixed!
  2. Jul 11, 2017 at 5:43 AM
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    Find a new and competent dealer, or DIY for best results. And No, it is not common at all on any new vehicle.
    I would invest $20 on a 1/2" torque wrench (harbor Freight) and crawl under and make sure the U-Bolts are torqued to 52lbs, make sure and use crisscross pattern or as you would a tire (X) four on each side.
    It's the least the dealer should have done for you and even though it may not stop the squeak now, its a start and should be checked anyway.
    Next you can bounce the vehicle and try to identify if its coming from the bushings at each end or in between the leafs.
    If it was me, I would loosen the bushing bolts (at each end of springs) and bounce the vehicle and while on the ground with full normal load or weight I would tighten the bolts at each end of of springs. You can also try and spray some AT-205 reseal all over them and between leafs, but no telling how long it will last.
    The permanent fix is proper installation of suspension components using proper torque with the normal (or the one you will carry) vehicle load on while torquing all suspension components, problem solved.
    Good luck
    Cheers!
    Torque U bolts to 52lbs
    Lub suspension
    https://www.youtube.com/watch?v=-wSVr4I5PLE
  3. Jul 11, 2017 at 6:28 AM
    AAChaoshand
    AAChaoshand Well-Known Member
    Brandon
    Central Texas
    2017 Nissan Titan SL 4x4
    Please do a search, many many people have had this issue. The resolution is to get them replaced under warranty.
  4. Jul 11, 2017 at 6:56 AM
    Scooby24
    Scooby24 Well-Known Member
    Greg
    2017 DCSB OR 4X4
    LOL, no. It's not. It's to clean them. Replacement springs, under warranty, will get dirty just like the originals will, and will also need to be have their pads cleaned at some point. Welcome to owning a truck.
    Gettin Lost and Jaque8 like this.
  5. Jul 11, 2017 at 8:57 AM
    AAChaoshand
    Brandon
    Central Texas
    It is the answer, mine have been dirty cleaned many times since mine were replaced at 5,000 miles. I'm sitting at 25000 now with no issues. Mine would squeak so loud that over any little bump or imperfection they would make noise. You could press down on the back of the truck and hear it. Get them replaced.
  6. Jul 11, 2017 at 9:00 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Or, clean the pads in the proper way. Sorry boss, Toyota sent out a TSB to the departments instructing they clean the pads instead of replacing the springs.
  7. Jul 11, 2017 at 9:01 AM
    AAChaoshand
    Brandon
    Central Texas
    Can you provide the TSB?
  8. Jul 11, 2017 at 9:26 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    T-TT-0429-16
  9. Jul 11, 2017 at 9:32 AM
    AAChaoshand
    Brandon
    Central Texas
    That TSB was what most dealers try initially but when it keeps coming back they replace them. Even lubed, mine would still squeak. They cleaned and lubed mine and it still squeaked like hell, as a result mine were replaced. They discovered the bushings/pads themselves were shot and there was no specific part number and is why the replaced both springs.
  10. Jul 11, 2017 at 9:37 AM
    Scooby24
    Greg
    2017 DCSB OR 4X4
    Your bushings were not "shot" after 5k miles of use. Either you're lying about what was done/said, or your tech was lying.
    Considering the Tech Tip came out in December and your post history claims yours were replaced last July, I'm inclined to believe the former.
  11. Jul 11, 2017 at 9:39 AM
    AAChaoshand
    Brandon
    Central Texas
    You must have been the service manager at my dealer to make those claims. Not going to argue with someone who wants to start internet keyboard wars. Calling someone a liar when you don't know them doesn't make your statements any stronger. Welcome to ignore. The leaf springs were bad and did need replaced.
  12. Jul 11, 2017 at 9:41 AM
    dnlskier
    dnlskier Well-Known Member
    17' TRD SPORT MT
    well this escalated quickly... :bananadead:
