Squeaky Belts
Discussion in 'Technical Chat' started by sikora8, May 2, 2010.
  1. May 2, 2010 at 3:46 PM
    sikora8
    sikora8 [OP] Active Member
    04' SR5
    Anyone changed belts on an 04 Tacoma 4wd. Have 125,000 on it and believe that they are original. I'm starting to hear a squeak when it starts up, usually only in the a.m. Don't know if its the belts, alternator, or an idler.
  2. May 5, 2010 at 2:56 PM
    BRP27
    BRP27 When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Mine does this also, it is probably a idler bearing. It is one of those noises that I know from the sound that it is not serious and it can wait untill I do the timing belt and water pump. i have 70,000mi.
    Does not sound like a belt to me, but I can't hear yours. FSM recommends timing belt @ 90,000 and you may as well do the water pump also. these are not interferance motors so if the belt goes, you walk, but it does not bend valves. I am assuming you have the V6.
  3. May 5, 2010 at 6:51 PM
    sikora8
    04' SR5
    Actually I have the 4 cylinder 5 speed. No timing belt to worry about....For the $60 dollar investment I believe I'll start with the belts and then go from there.
  4. May 5, 2010 at 6:58 PM
    tacomakid96
    tacomakid96 Can you skin Grizz, pilgram?
    Phil
    Out n' about
    2008 Tundra
    When does the water pump need to be replaced?
  5. May 6, 2010 at 4:51 AM
    BRP27
    04 4X4 Tacoma SR5
    On the V6 we change them with the timing belt @90,000 since it has been seen to fail around this time and you are in there. Dont know on the 4s
