Squeaky Brakes
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 07TACOTRDSPORT, Jun 3, 2008.
  1. Jun 3, 2008 at 6:36 PM
    07TACOTRDSPORT
    07TACOTRDSPORT [OP] Active Member
    MOORE, OK
    07 PRERUNNER SR5 TRD SPORT X CAB
    PIONEER AVIC D3 GPS XM RADIO
    I Just Rolled Over 8k Miles On My 07 Trd Sport. The Brakes Are Starting To Squeel When I Come To A Soft Stop. Is This Just The Type Of Pads Or Is This A Problem? Anyone Else Experience This?
  2. Jun 3, 2008 at 6:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I have experienced this a few times. I dosent bother me.
  3. Jun 3, 2008 at 6:54 PM
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    yeah, I am. My brakes have maybe close to 9k miles on them. I took it in and the guy told me that its the pads. It will get down to a sertant point and change metals and thats what the squeeking is. Then it will wear through that section and should be gone, so he sais... I still have it after a thousand mile after it started.
  4. Jun 4, 2008 at 3:54 AM
    tjdriscoll
    tjdriscoll Active Member
    07, Tacoma Std Cab, 2WD, 5-M, 2.7 L I4, Indigo
    OEM Foglights, iPod adapter, Bedlights-Underbody lights, more to come soon.
    yeah i have the same problem, i rotated the tires and now the rear drivers side brake squeaks when i tap the brakes (rear drum). eventually it goes away but its just annoying. i only have 9k miles on my taco too.
  5. Jun 4, 2008 at 4:52 AM
    MikeM
    MikeM Well-Known Member
    Florence, KY
    17 TRD Sport 4x2 DCSB Blazing Blue Pearl
    Bright stuff
    On my Porsche, the brake pad manufacturer (HAWK) and some track friends suggested finding a isollated spot where I could do some hard stops where I could run up to 45-55 mph and then stop hard to where the the ABS starts to kick in , let cool and then repeat for 4-5 times. ( not much more as you will get brakes/rotors to hot, so let them cool afterwards, also after doing this, don't set the parking brake til they completely cool to not to cause any warpage) This is similar to bedding in new pads.
    When I tried it it did clear up the squeal which is caused by excessive dust/glazed surfaces.
    You have enough miles that the brakes are broken in at this point.
    It's also give you a chance to check you ABS on dry pavement.
    Hawk Pad link for bedding in new pads
    http://www.hawkperformance.com/performance/hps.php#
    Also if you look at FAQ on the site it has good info as to what other causes of brake squeals.
    Give it a try.
    Mike M
  6. Jun 4, 2008 at 5:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Thats a good idea. I heard of people doing this before with good results. :)
