Squeaky car help..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Karo, May 24, 2010.
  1. May 24, 2010 at 11:18 AM
    Karo
    Karo [OP] Well-Known Member
    Karo
    La Crescenta, CA
    06 PreRunner TRD Sport
    Grill
    I have a 2006 DC LB Sport and I recently noticed that it squeaks all the time. From bumps on the road to just getting in and out of the truck itself. Sometimes its embarrassing in front of others because it makes me look like a fat ass getting out of the truck. Does anyone know what it is from and how exactly to fix this annoying problem?
  2. May 24, 2010 at 11:21 AM
    winterboy04
    winterboy04 Professional Cube-Jockey
    MA
    07 SR5 TRD (Bright Red)
    Alpine CDA-9886 Hybrid Audio Unity Series components JL 250.1, JL300.4 Infinity Perfect 10.1 SVC 4ohm in custom enclosure / amp rack Alpine PXA-H100 Processor FatMat everywhere URD short shifter OEM Bed Mat Tail Gate Safety Mod (Plumbing clamps) Pro-Dry S Filter
    It's the rear leaf spring TSB. Just do a search for it in the forums and you can get part numbers and everything. I ordered the "plates" and am putting them in this weekend ($21 bucks from the dealership).
    Its caused by the leaf springs rubbing on each other, the plates are designed to sit in between them and "lubricate" the movement...my truck does the exact same thing. If you are under warranty you can get this covered by complaining at a toyota dealership.
  3. May 25, 2010 at 1:43 AM
    Karo
    Karo
    La Crescenta, CA
    Grill
    Would there be any way you can post the "how-to" pictures on TW? Or are you going to have the service people at the dealer take care of it for you?
  4. May 25, 2010 at 5:44 AM
    dgalleon
    dgalleon Well-Known Member
    Central Florida
    09 TRD Sport 4x4 Dbl Cab LB
    TRD CAI, Flowmaster 40 series, 6" Fabtech Lift, Dirt Logic rear shocks
    I had all the TSB's done (4 leaf pack and silencer pads) and it stopped until i got back into the mud and it started again... lifted the truck on a lift and cleaned between each leaf... noise is still there... lubed and goes away for a week then it comes back... :mad:
  5. May 25, 2010 at 8:15 AM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
    If you don't travel in a lot of mud (ie normal driving), you should be able to hose them out really well, let them dry, then spray some chain lube in between the leafs. I used to have to do this every 6 months, but it's been over a year since I had to do it last time. I prefer the chain lube over things like wd40 because it's thicker and tends to not wash off as easily in the rain which causes it to last longer.
  6. May 25, 2010 at 8:17 AM
    wilsonpj
    wilsonpj Well-Known Member
    Pete
    Boulder, CO
    2006 DC, SB, OR
    OME 3in Lift, LR UCA's, 33in DuraTracs, All-Pro Full Skids, TRD CAI & Cat Back, 16x8 KMC Enduros
    What are these plates you are talking about? Do you have a part no or a link or more info?
  7. May 27, 2010 at 5:32 AM
    winterboy04
    MA
    Sorry, i guess i didn't subscribe to the thread so i missed the question
    The Service Bulletin is # T-SB-0274-09 (this REPLACES T-SU012-07). It is covered under the 36K warranty for 05-09's, otherwise i have heard the cost is between 75 and 100 bucks, depending on your "stealership" (this is what i have heard, i still have yet to get mine done)
    The "Plates" i am talking about are these plastic circles about 1/8" thick and about the size of a half dollar. they have a raised "slot" in the center of each and they are designed to sit between the springs (again, so i am told). The part number is 04009-09104 (previously 04005-36104) and it is called a "Silencer Kit RR". cost me 21 bucks
    All this info can be found in the attached TSB. I apologize for telling people to "search for it" before, i just didn't have it all ready. It drives me up an F'ing wall when someone takes the time to actually post "Search the Forum" when they have the info quickly accessible, but just want to be dinks.
    My noise is out of control, so i am trying to find somewhere i can get a lift high enough to release the springs...
  8. May 27, 2010 at 7:28 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    you cant just apply lube between the leafs?
  9. May 27, 2010 at 8:24 PM
    RTG
    RTG Well-Known Member
    League City, TX
    06 PreRunner TRD Sport SRR5, Long Bed
    6" Fabtech Dirt Logic, PA15-TOY IPOD adapter, UltraGauge, CravenSpeed 2" antena, 17x9 Moto Metal Wheels, 35sx12.5 Yokohama Geolander M/T tires, Removed second filter, Pop&Lock, Bed Extender, Bug Deflector, Grill Craft, Two 12" Rockford Fosgate punch sub enclosure, Kicker Amp, 5902 Viper Remote start, Tint (20% all around), Power Slot Rotor, NFAB Step Bars, AFE Pro Dry S Air Filter, Wet Okole seat covers, akebono brake pads, Foglights Mod,Bushwacker fender flares,Homeblaster trainhorn.
    I just got my truck back today after intalling a 6" Fabtech lift and started hearing squeaks. I'll find out tomorrow and will let you know what the shop says.
  10. May 28, 2010 at 5:42 AM
    winterboy04
    MA
    yes, you can install lube, but (only from what i have HEARD) these supposedly remove having to do that from the equation. Either way, the noise HAS to go...i sound like i weigh 2 tons gettign out of my truck. And it is way nastier in the heat....
  11. May 28, 2010 at 2:28 PM
    Karo
    Karo
    La Crescenta, CA
    Grill
    i just washed the leafs and resprayed them with dry lube thoroughly and the squeak is now gone
