Squeaky/Chirping Sound from Driver's Side Front Wheel - 2009 TRD Sport
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Jaxon.NW, Aug 6, 2024.
  1. Aug 6, 2024 at 3:17 PM
    Jaxon.NW
    Jaxon.NW [OP] Active Member
    2009 Tacoma TRD Sport
    Hey TacomaWorld,
    I've been dealing with a persistent squeaky/chirping sound coming from the driver's side front wheel of my 2009 TRD Sport. The noise is inconsistent but loud when present. It is synced with wheel rotations, and when I turn right (putting weight on the left side), it gets louder. However, when I turn left (putting weight on the right side), the noise goes away for a second.
    I have Bilstein 5100s with OEM springs. As far as I know, no suspension maintenance was performed by the first owner. The truck currently has 130k miles. It could be a wheel bearing, tie rod, or ball joint maybe?
    Has anyone experienced something similar or have any ideas on what it could be? Any advice or suggestions would be greatly appreciated!
    Thanks!
  2. Aug 7, 2024 at 12:44 PM
    robson1015
    robson1015 Well-Known Member
    Bob
    New Concord, Ohio
    2009 base tacoma- regular cab- 5 speed
    Probably a rock stuck inside the dust shiels against the rotor. Check that first
  3. Aug 7, 2024 at 1:01 PM
    Jaxon.NW
    I actually swapped in a new set of rotors last week and checked the shields for rocks. Unfortunately, the sound started before that.
  4. Aug 12, 2024 at 8:50 AM
    Jaxon.NW
    Hey TacomaWorld,
    I wanted to provide an update on the chirping sound coming from my driver's side front wheel. After a weekend of offroading, the noise has become more consistent and louder, but it still doesn't seem to affect the drivability of the truck. The sound is especially noticeable during right turns or when weight is on the left side.
    Given this new information, I'm wondering if this could be related to the CV axle or possibly a bearing somewhere in there. Does anyone have experience with similar symptoms? Any advice or suggestions would be greatly appreciated!
    Thanks!
  5. Aug 12, 2024 at 10:18 AM
    MAG GRY TACO15
    MAG GRY TACO15 Well-Known Member
    Alan
    GA
    '15 TRD Off-Road
    Same crap everyone else got
    Have you jacked up the front and just free spun the wheel to see if you can pin point the sound?
  6. Aug 13, 2024 at 8:11 AM
    Jaxon.NW
    I got it up in the air when I swapped the rotors and couldn't find anything when I spun the wheel. It seems like a weight has to be on the wheel, which leads me to believe it could be suspension-related. Has anyone had coils or anything in there consistently chirp at you?
