squeaky clutch...after recall fix
Discussion in '2nd Gen. Tacomas (2005-2015)' started by forana, Jun 6, 2015.
  1. Jun 6, 2015 at 11:33 PM
    forana
    forana [OP] Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    Hi All, question for you folks. I have a 2012 DCSB 4x4 manual and had the squeaky clutch recall done 2 years ago. The squeak is back! Anyone have any similar experiences with this? I'm going to call toyota and see if there's anything they can do as the recall work was done and the truck is no longer under warranty.
  2. Jun 7, 2015 at 12:24 AM
    Taco Pete626
    Taco Pete626 Well-Known Member
    Peter
    Southern California
    2013 Regular Cab 5-spd (Sold )
    - Undercover Flex tonneau cover - Pop N Lock tailgate lock - Weathertech DigitalFit floor liner - Sick Speed Ol' Skool white shift knob - Bench seat mod - Wiper mod - Cruise control mod
    There some good info here
    If you just search "clutch creak" or "squeak" you will come up with a lot of hits. Some say the TSB worked for them, others did the TSB only to have the sound come back the next day. There have been a some solutions suggested by a couple of very wise TW members.
    For me this has worked:
    1) Creak coming from the clutch pedal - Grease the shaft that goes from the pedal to the master cylinder, rotate the shaft and pump the clutch to disperse the grease. Repeat whenever the creaking comes back.
    2) Squeak/Creak from outside the truck - Look underneath the truck for the slave cylinder, peal back the dust boot, apply grease inside, disperse grease, reinstall dust boot, pump clutch. Repeat when necessary.
    Should you decide to have the TSB performed without warranty, fyi, my dealership quoted me over 800 dollars including labor to perform the task.
  3. Jun 19, 2015 at 12:33 PM
    forana
    Kaneohe, Hawaii
    OK so I checked out my clutch and was read to grease the shaft (hehe). Anyway when I checked it out the shaft seemed perfectly fine. When I looked closer it was actually the coiled spring that was doing all the squeaking. When the spring was compressed it squeaked a lot. So I greased the crap out of it and the whole area. Squeaking stopped!!
    But its slowly coming back...
    damn
