Squeaky Clutch Pedal...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MotoXFreeStyle61, Aug 12, 2008.
  1. May 25, 2017 at 11:51 AM
    #101
    Pisan1
    Pisan1 Well-Known Member
    2016 Black Tacoma TRD Sport DCSB 4x4 MT
    Not sure what they did yet. They are going to mail me the paperwork, as I had to leave and didn't have time to wait for the write up and it was covered under warranty. Once I get the details I will share.
    It's like driving a new truck. It feels great. Hoping this will be a permanent fix.
    scottalot[QUOTED] likes this.
  2. May 25, 2017 at 11:57 AM
    #102
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Same thing happened to me. They replaced a whole bunch of parts, and the clutch felt SMOOTH. Then the squeak came back 8 months later. Took it back in and they greased something and it made the squeak go away. Traded the truck in before I gave it a chance to come back.
    scottalot likes this.
  3. May 25, 2017 at 12:01 PM
    #103
    Pisan1
    Ugh...Well, I look forward to 8 months of smooth quiet clutch driving.
  4. May 25, 2017 at 12:01 PM
    #104
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Hopefully it's better for you. At least you can keep getting it fixed under warranty!
  5. May 25, 2017 at 12:04 PM
    #105
    Pisan1
    It's amazing, really. After time I would start to hear the squeak and could feel, in the clutch travel, when it was squeaking.
    Now it's very smooth, like a new clutch. You can't feel or hear any of the old issues.
    Based on other's remarks it may come back, but I'll enjoy the ride for the summer
    :burnrubber:
  6. May 25, 2017 at 12:53 PM
    #106
    dmarsh15
    dmarsh15 Well-Known Member
    David
    Rochester, NY
    2010 Tacoma V6 SR5 MT ACLB
    Function Over Form
    I bought a my 2010 Tacoma a couple months ago and I had the squeaky clutch pedal TSB done under warranty a week after I bought it. I also noticed that I couldnt always get a smooth shift out of first gear and sometimes when the truck was cold, 1st gear would slip and the whole truck would shutter until I pressed the clutch back in then restarted. I took it to the dealer today and they are doing 2 other TSB's to cover it.
  7. May 25, 2017 at 4:30 PM
    #107
    will.carroll7
    will.carroll7 Well-Known Member
    2023 DCSB TRD OR 4x4 LR
    Oh lol. Didn't even look at the post date. Just saw this thread on the front page list.
  8. May 25, 2017 at 7:38 PM
    #108
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    Mine was doing this. It's a bitch to get to but I hosed the pivot point down with WD-40, the new stuff with blue torque technology or something like that, and it's been quiet for several months now.
    It took me two shots because I really had to contort to get under the dash to see it well enough.
    I think it's been about six months now.
  9. May 28, 2017 at 12:20 AM
    #109
    Pisan1
    Here are the details on the repair from the Toyota service rep:
    REPLACED CLUTCH PEDAL WITH CLUTCH MASTER CYL AND SUPPLY HOSE GREASE 5 POINTS OF MOVEMENT ~|~C/S SQUEEK FROM CLUTCH PEDAL//PARTS IN ~|~C-C/S CLUTCH PEDAL SQUEEK,C-PEDAL AND BRACKET NOT ALIGNED CAUSING SQUEEK, R R&R PEDAL, CLUTCH MASTER AND SUPPLY HOSE WITH NEW FLUID
  10. Jan 2, 2018 at 7:00 AM
    #110
    TheManInDboX
    TheManInDboX Well-Known Member
    Columbus Ohio
    I know this is an older thread, but my 2015 tacoma does this.. But then my 1985 Camry did this, 1986 celica, 1992 previa, 1999 corolla, and 2005 Scion Xb.. All of which did this for over 200K miles... Some had metal assembly parts, some rubber, some plastic.. all were caused by heat from the position of the floor heater in reference to where the assembly is located.. A permanent solution is to re-route the floor heater duct work under the dash to another position, or plug the drivers side foot heat vent with something.. (in the winter) in the summer, the AC will actually stop it from happening.. You can twist this, or lube that, but over time nothing actually fixes the issue permanently.. and will make you become a professional contortionist.. Might be good for your romantic life, but will just lead to aggravation when shifting gears..
    Typically the issue for me was caused by this 10 dollar part.. 90949-03136 which is the return spring, that binds on the plastic fittings on the metal cage.. The problem i get is that with the different metals and materials, you seem to get different rates of expanding, or contrasting, causing the binding feeling..
    I can't speak for everyone here, but it's not a uncommon toyota issue, and at least for me, never caused anything outside of an annoyance..
    scottalot and EatSleepTacos like this.
  11. Jan 26, 2018 at 12:15 AM
    #111
    05Taco4x4
    05Taco4x4 ToyotaHubs
    2TR-FE Enthusiast
    FJ Tcase, Manual Hubs, 2017 Head unit, Mirror Riser
    Yeah, this squeak is driving me nuts- gf actually asked me why it squeaks all the time :annoyed:
  12. Apr 6, 2018 at 2:19 PM
    #112
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    I used some tri-flow dry lube on the push rod in my 6spd yesterday, and my clutch pedal is silent now! Might give this a shot man!
    05Taco4x4[QUOTED] and scottalot like this.
  13. Apr 6, 2018 at 2:25 PM
    #113
    BassAckwards
    Definitely do! Its a pita to get the little bottle up there above where the top of the push rod is, but once you do just let it drip down in there. I did that and then pushed the clutch in and out several times and repeated that until it quieted down. Silence is bliss:D
  14. Apr 6, 2018 at 2:28 PM
    #114
    BassAckwards
    @scottalot also be sure to put a towel or napkin on the floor below the clutch pedal to keep any excess from getting in your carpet.. i have all weather flooring in mine so it was easy to clean up, but id have been pissed at myself if i had carpet..
  15. Apr 6, 2018 at 2:32 PM
    #115
    BassAckwards
    Sure did man! It was a cake walk. A huge upgrade over the carpet for sure!
    I have a few pics and part #s in here:
    https://www.tacomaworld.com/threads/oem-all-weather-flooring-part-numbers.443444/#post-12914966
  16. Apr 6, 2018 at 5:14 PM
    #116
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    This happened to my truck and I tried WD-40 multiple times with no success. Heres what you do:
    1) Remove the drivers seat. I know it sounds extreme, but hear me out. The seal removal is super easy, 4 bolts and a couple wire plugs underneath. This will allow you to lay on your back where the seat used to be and work on the necessary area.
    2) Buy white lithium grease. Sticks to high heaven, is a pain to work with, but it's the answer.
    3) Lay in your truck where the seat used to be and literally grease every moving part, pivot, spring and rod that has anything to do with your clutch petal.
    4) Reinstall the seat and enjoy squeak free clutch function.
    scottalot and BassAckwards like this.
