Squeaky clutch pedal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Light-tower, Oct 3, 2007.
  1. Oct 3, 2007 at 7:09 PM
    Light-tower
    Light-tower [OP] Well-Known Member
    So I went to the dealer to get 2 problems solved.
    TSB #TC004-06 JUN 06 M/T - Clutch Pedal Squeaking Noise
    and
    TSB SU006-007 addresses bottoming-out problem.
    They had the vehicle for a day and they told me that the rear leaf springs will not be in stock until the 22nd:rolleyes:
    They never noticed any clutch pedal noise either:rolleyes:
    Tell me if you can hear it!:
    http://www.youtube.com/watch?v=QpeYjUXUhEU
    Now, I only have 2800km left before the warranty expires...this is going to be close.
  2. Oct 4, 2007 at 5:42 AM
    rjmcmillan
    rjmcmillan Member
    Calgary, Alberta
    2005 Tacoma Sport SB
    I got the squeaking clutch fixed in 2006 and it took them a year to get my new clutch assembly adjusted correctly. First they greased the original, but the squeak returned, then they replaced the assembly but installed it incorrectly. Installed another assembly and installed it wrong....had to get Toyota Corp Techs work through it with the dealership and now its fine.
    Just got the replacement leaf springs done last week and what a difference...no more rattles or squeaks and rides much better.
  3. Oct 4, 2007 at 3:34 PM
    Light-tower
    How long did you have to wait for the springs? There talking a month up here!!
  4. Oct 4, 2007 at 3:53 PM
    rjmcmillan
    rjmcmillan Member
    Calgary, Alberta
    Same day....I asked about it when they were fixing my clutch and they did it at the same time. I guess I got lucky with the springs.....Clutch took forever though....
  5. Oct 4, 2007 at 4:22 PM
    Light-tower
    I got exactly 2400km left on the warranty so I hope it comes in a few weeks:D
  6. Oct 4, 2007 at 4:42 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    I would think that since you have brought it to their attention before the warranty expired, and got the ball rolling on it, then it could take 3 months to come in, and it would still be taken care of. Afterall, it is not your fault or problem that your dealer didn't have to parts. If that were the case then every dealership would drag their feet on a problem untill the warranty expired, and then tell the customer tough luck.
    You're good, you're covered. Don't worry about it.
