Squeaky clutch pedal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2019Trdoffroad, Mar 9, 2019.
  1. Mar 9, 2019 at 8:20 AM
    2019Trdoffroad
    2019Trdoffroad [OP] Member
    Kyle
    2019 Trd off-road
    New to the page, I have a 2019 off-road 6 speed manual with only less then 6000 km and getting a squeak in the clutch pedal what’s everyone doing to solve this problem?
    Gunnar_19 and Nunya Bizness like this.
  2. Mar 9, 2019 at 8:20 AM
    Shellshock
    Iowa
    Disc brake grease on the pivot points and spring
    MOC221_, shakerhood, fdbyrne and 2 others like this.
  3. Mar 9, 2019 at 8:22 AM
    Nunya Bizness
    I had this pop up on my 18 after a snow storm and after tracking in some snow and moisture into the cab. I just lightly greased the pivot points and it went away.
  4. Mar 9, 2019 at 8:23 AM
    2019Trdoffroad
    Kyle
    2019 Trd off-road
    Do you take the whole assembly apart and do it or just what you can get at, ive greased what i could from inside the truck but never did the spring
  5. Mar 9, 2019 at 8:25 AM
    2019Trdoffroad
    Kyle
    2019 Trd off-road
    I’m a Technician at my local dealer and everyone says they just greases it but I can’t get it to go away
  6. Mar 9, 2019 at 8:32 AM
    Z2A6X2
    Z2A6X2 Well-Known Member
    Zach
    2019 DCSB Off Road 6MT
    My dealer completely replaced my clutch pedal assembly under a TSB. I would ask about it.
    Boghog1 likes this.
  7. Mar 9, 2019 at 8:33 AM
    2019Trdoffroad
    Kyle
    2019 Trd off-road
    Sounds good I’ll look into it Monday
  8. Mar 9, 2019 at 8:52 AM
    jersey jim
    jersey jim Well-Known Member
    Jim
    2018 Cement DCSB TRD Sport 4x4 6MT
    They replaced the pedal assembly on my '18 as well, tech used a TSB for '17 when he did it. So far so good.
  9. Mar 9, 2019 at 9:11 AM
    2019Trdoffroad
    Kyle
    2019 Trd off-road
    Anyone know what tsb it is
  10. Mar 9, 2019 at 9:15 AM
    Ez2Tan
    Ez2Tan Well-Known Member
    2017 Quicksand Tacoma OR
    I brought it to the dealer and they replaced the assembly. But I was also getting this chatter starting 2k below redline and up.
  11. Mar 9, 2019 at 9:16 AM
    Shellshock
    Iowa
    I didn’t take mine apart. I just globbed some on and worked it in as best I could. Dealer did same thing to fix my brothers. Seems most just do a couple times a year
    shakerhood likes this.
  12. Mar 9, 2019 at 9:20 AM
    2019Trdoffroad
    Kyle
    2019 Trd off-road
    I will give that a try like I said before never did the spring last time
  13. Mar 9, 2019 at 9:29 AM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
  14. Mar 9, 2019 at 9:35 AM
    DTaco18
    DTaco18 Well-Known Member
    2025 TRD SPORT DCSB 8AT CSM
    Mine was the rod rubbing on the rubber boot. Silicone brake grease on the rod made the squeek go away and hasn't came back.
  15. Mar 9, 2019 at 9:37 AM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    I tried to grease mine as well last year but still squeaked when it was really hot/humid out. I took it in and they also replaced my assembly under the TSB, been fine since but it is winter. Time will tell.
  16. Mar 9, 2019 at 10:18 AM
    mtip
    mtip Go Outside & Play!!!
    South Louisiana
    18 TRD Sport 6MT 00 Tundra 5MT
  17. Mar 9, 2019 at 10:38 AM
    Arries289
    Arries289 Yo!
    Franklin TN
    2018 TRDOR DCSB BBP 6MT Tech & Prem
    Mine started squeaking as well at 5K miles. I sprayed some white lithium on the main pivot point and it and it went away.
  18. Mar 9, 2019 at 11:33 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Regular greases and sprays will all temporarily help but they will melt or wear away and the old barn door sound will shortly return. Disc Brake Grease on all the pivot points is by far the best choice as it will not melt away.
    mtip likes this.
  19. Mar 9, 2019 at 12:27 PM
    jschares
    jschares Member
    Jacob
    2016 TRD sport DCSB Quicksand
    By disc brake grease are you referring to silicone grease or something else?
  20. Mar 9, 2019 at 12:41 PM
    shakerhood
    Southern Ohio
    If you go to the Auto Parts store you can ask for Disc Brake Grease, they will either give you the little packets or a small jar.
